01-01-2016 10:32 PM - edited 03-12-2019 12:05 AM
I'm trying to SSH into a vty line on my router that is sitting on the OUTSIDE interface of an ASA. I have tried from the actual router and a PC inside the ASA to and i'm getting the same "Open" message and go to enter the password but when i enter the password and hit enter it does nothing and just times out.
Will post the relevant config for router and ASA below:
hostname Router3
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
aaa new-model
aaa authentication login loginlist group radius
aaa authorization exec authorlist group radius
username bob privilege 15 secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip ssh version 2
ip domain-name ROUTER3
interface FastEthernet0/0
ip address 172.16.30.1 255.255.255.0
duplex auto
speed auto
ip classless
ip route 10.30.0.0 255.255.255.0 172.16.30.2
ip route 0.0.0.0 0.0.0.0 172.16.30.2
ip flow-export version 9
radius-server host 10.30.0.10 auth-port 1645 key Secret
radius-server key Secret
line con 0
line aux 0
line vty 0 4
login authentication loginlist
transport input ssh
line vty 5
transport input ssh
line vty 6 15
transport input ssh
end
_______________________________________________________________________________________________________________
Firewall ASA
hostname ASA2
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 30
interface Ethernet0/2
interface Vlan1
no nameif
security-level 100
no ip address
interface Vlan2
nameif outside
security-level 0
ip address 172.16.30.2 255.255.255.0
interface Vlan30
nameif inside
security-level 100
ip address 10.30.0.1 255.255.255.0
webvpn
enable outside
enable inside
route outside 0.0.0.0 0.0.0.0 172.16.30.1 1
access-list VPN_1 extended permit icmp 10.30.0.0 255.255.255.0 10.20.0.0 255.255.255.0
access-list test extended permit icmp 10.20.0.0 255.255.255.0 10.30.0.0 255.255.255.0
access-list test extended permit icmp host 172.16.30.1 host 10.30.0.10
access-list aaa extended permit udp any 10.30.0.0 255.255.255.0 eq 1645
access-group aaa in interface outside
group-policy webvpn internal
group-policy webvpn attributes
vpn-tunnel-protocol ssl-clientless
webvpn
url-list value test1
username bob password 4IncP7vTjpaba2aF encrypted
username bob attributes
vpn-group-policy webvpn
class-map inspect
match default-inspection-traffic
class-map test
policy-map global
class inspect
inspect icmp
class test
service-policy global global
telnet timeout 5
ssh timeout 5
Also, the details in packet tracer on the radius server are:
client name = R1 client ip= 172.16.30.1 service type=radius key=Secret port=1645
username= tim password= pass
01-04-2016 12:49 PM
Hello;
What happens if you remove authorization? Are you able to get in?
Mike.
01-04-2016 04:17 PM
No it still doesnt let me, i have changed the access lists arounf a bit to see if anything works. I am now able to ping from the outside router to the AAA server but cannot SSH into the router from an inside PC and get the radius authentication to work also.
Here are the new updates:
object network asa_inside_address
subnet 10.30.0.1 255.255.255.255
object network inside_network
subnet 10.30.0.0 255.255.255.0
access-list website_outside extended permit icmp any object asa_inside_address
access-list website_outside extended permit udp any 10.30.0.0 255.255.255.0 eq 1645
access-list website_outside extended permit icmp any object inside_network
access-group website_outside in interface outside
I must be missing something cant see what?
