Cisco AP1852 firmware
how can i upgrade AP1852, to be managed with Controller?
i erase storage with button MODE.
using console i cannot edit cli:
<Meraki> en
UNRECOGNIZED COMMAND LOGGED TO CLOUD SERVERS.
i cannot login with telnet, because i cannot use any login/password.
I see that AP broadcast SSID, I can connect to AP by wireless.
there is no configuration option in Web interface to upgrade AP.
can you help how can i upgrade AP?
may be bootloader?
thanks.
No.  I would ask the person whom gave that to you, because they would know.  That isn't something documented to the public. As you can see, that AP was being used to test something. Ask your colleague for another AP and give that one back to him.
Nothing you can do with that. I would be careful also because you might get your colleague in trouble since that was a beta AP and has the Meraki image.
-Scott
-Scott
21 Replies 21
Scott Fella
You want the 1852 to be the controller using Mobility Express or actually join an existing AireOS controller?  Only autonomous AP have the enable command, lightweight AP's don't.
-Scott
-Scott
I want to connect AP1852 to COntroller 5500.
AP1852 doesn't join controller, so i wanted to update it and set controller ip. I cannot configure AP1852 because it doesn't provide any cli command.
The 5508 is on version 8.1.121.0 or newer?  Post the show version from the AP.
-Scott
-Scott
controller version 8.1.131.0
AP version cannot be shown.
console connection:
<Meraki> show version
console log during AP boot during start:
This product contains some software licensed under the
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
[* 12.619056] Made it into bootsh: Jun 16 2015 14:13:46
[* 12.624554] bootsh build T-d932a68a43ec75b74aa0ce28dbaee445b267f55eM-gedfce3 cd-miwellin
init started: BusyBox v1.20.2 (2015-06-10 15:57:55 CDT)
WARNING! THIS CONSOLE IS LOGGED! UNAUTHORIZED ACCESS FORBIDDEN!
<Meraki> [* 14.254545] Last reload time: Jan 14 13:31:26 2016
[* 14.305873] Latest syslog time: Jan 14 14:59:52 2016
[* 14.310278] Updated last reload time!!
[* 14.314870] Thu Jan 14 14:59:52 UTC 2016
[* 14.514432] copy part1_info.ver to CAPWAP_VERSION.
[* 14.520368] part2_info.ver does not exist. CAPWAP_BAK_VERSION is 0.0.0.0
[* 14.728928] nss_driver - Turbo Support 1
[* 15.508278] click: starting router thread pid 1081 (eeda4500[ 15.551233] s tile module dp init successfully
[ 15.615182] module build date: May 28 2015 at 21:42:51
[* 15.527241] stile_lm_ft_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[* 15.546860] stile_lm_dp_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[* 15.718837] elts_meraki: module license 'unspecified' taints kernel.
[* 15.788503] S10boot: file "/storage/rxtx_mode" found.
[* 15.800781] pid 1081's current affinity mask: 3
[* 15.800781] pid 1081's new affinity mask: 2
[* 15.820087] pid 1133's current affinity mask: 3
[* 15.820087] pid 1133's new affinity mask: 1
[* 16.077132] nss_macsec init success
[* 16.135738]
[* 16.141299] boot 5 build T-d932a68a43ec75b74aa0ce28dbaee445b267f55eM-gedfce3 cd-miwellin board corsica mac A0:EC:F9:6C:E3:68
[* 16.145298] Module: qca_nss_gmac .text=0xbf000000 .data=0xbf00792c .bss=0xb f007da0
[* 16.145298] Module: qca_nss_drv .text=0xbf012000 .data=0xbf021d68 .bss=0xbf 022998
[* 16.145298] Module: qca_nss_capwapmgr .text=0xbf037000 .data=0xbf03aaf8 .bs s=0xbf03ac50
[* 16.145298] Module: nssmgrctl .text=0xbf040000 .data=0xbf04171c .bss=0xbf04 1a48
[* 16.145298] Module: proclikefs .text=0xbf047000 .data= .bss=0xbf047b40
[* 16.145298] Module: merakiclick .text=0xbf04c000 .data=0xbf13a718 .bss=0xbf 13a980
[* 16.145298] Module: stile_lm_ft .text= .data= .bss=
[* 16.145298] Module: stile_lm_dp .text= .data= .bss=
[* 16.145329] Module: elts_meraki .text=0xbf5cd000 .data=0xbf877eac .bss=0xbf 879010
[* 16.145329] Module: qca_nss_macsec .text=0xbfa61000 .data=0xbfa6bcc0 .bss=0 xbfa6be6c
[* 16.145329] Module: qca_nss_profile_drv .text=0xbfa7f000 .data=0xbfa80324 . bss=0xbfa804a0
[* 17.499500] adf: module license 'Proprietary' taints kernel.
[* 17.509153] asf: module license 'Proprietary' taints kerne[ 17.584192] PCI device id is 0040 :0040
l.
[* 17.521055] ath_hal: module license 'Proprietary' taints[ 17.669103]
[ 17.669103] ol_ath_pci_configure : num_desired MSI set to 0
kernel.
[* 17.532771] ath_dfs: module license 'Proprietary' [ 17.820649]
[ 17.820649] Using PCI Legacy Interrupt
[ 17.948766] chip_id 9 chip_revision 1
[ 17.994033]
[ 17.994033] HIFDiagReadMem address 0x4008f8 data ead6bc00 nbytes 4
taints kernel.
[* 17.542736] ath_rate_atheros: module license[ 18.087316]
[ 18.087316] HIFDiagReadMem address 0x401e90 data ead6bc04 nbytes 4
[* 17.553889] ath_dev: module l[ 18.247672]
[ 18.247672] HIFDiagReadMem address 0x401e94 data ead6bc08 nbytes 4
[ 18.407091]
[ 18.407091] HIFDiagReadMem address 0x401eb0 data ead6bc0c nbytes 4
[ 18.538300]
[ 18.538300] HIFDiagReadMem address 0x400900 data ead6bc0c nbytes 4
[ 18.630990]
[ 18.631021] CLOCK PLL skipped
[ 18.684129] HIF_PCIDeviceProbed: setting the target pll frac ffffffff intval ffffffff
[ 18.777819] HIF_PCIDeviceProbed: no frac provided, skipping pre-configuring P LL
[ 18.865323] HIF_PCIDeviceProbed: ar900b_20_targ_clk is not provided, skipping pre-configuring PLL
[ 18.971571]
[ 18.971571] HIFDiagReadMem address 0x4008cc data ead6bc0c nbytes 4
[ 19.066479] __ol_ath_attach: ath_attach TODO
[ 19.115338] __ol_ath_attach 1799 host_enable 0 nss_nwifi_offload 0
[ 19.189284] __ol_ath_attach: dev name wifi0
[ 19.239268] ol_ath_set_default_tgt_config : AC Minfree buffer allocation thro ugh module param (umac.ko)
[ 19.351827] OL_ACBKMinfree : 0
[ 19.389253] OL_ACBEMinfree : 0
[ 19.426772] OL_ACVIMinfree : 0
[ 19.464261] OL_ACVOMinfree : 0
[ 19.501780] ol_ath_attach() BMI inited.
[ 19.547703] ol_ath_attach() BMI Get Target Info.
[ 19.602811] ol_ath_attach() TARGET TYPE: 9 Vers 0x1000000
[ 19.667416]
[ 19.667416] CE WAR Disabled
[ 19.719681] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
[ 19.784254] ol_ath_attach() configure Target .
[ 19.837269]
[ 19.837300] Target Version is 1000000
[ 19.899750]
[ 19.899750] Flash Download Address c0000
[ 19.967478] ol_transfer_bin_file: flash data file defined
[ 20.032021] Cal location [0]: 00000000
[ 20.076788]
[ 20.076819] Wifi0 Select OFFSET 1000
[ 20.157232] qc98xx_verify_checksum: flash checksum passed: 0x848c
[ 20.217806] ol_transfer_bin_file 2973: Download Flash data len 12064
[ 20.294033] Board extended Data download address: 0x0
[ 20.374632]
[ 20.374632] Board data initialized
[ 20.421774] Flash download ADDRESS 0xc0000
[ 20.470696]
[ 20.470696] Selecting OTP binary for CHIP Version 1
[ 20.594939]
[ 20.594939] First OTP send param 8000
[* 22.451077] pid 1276's current affinity mask: 3
[* 22.451077] pid 1276's new affinity mask: 1
[ 25.268166] ol_ath_download_firmware :First OTP download and Execute is good return param 40960
[ 25.362199]
[ 25.362199] ##Board Id 8
[ 25.410059]
[ 25.410059] ##CHIP Id 1
[ 25.457606]
[ 25.457606] BOARDDATA DOWNLOAD TO address c0000
[ 25.530615] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR90 0B_CUS260_negative_pwr_offset_2G_v2_008.bin ARXXXX v=0x1
[ 25.686879] Board extended Data download address: 0x0
[ 25.755513] ol_ath_download_firmware: Using 0x1234 for the remainder of init
[ 25.834739]
[ 25.834739] Selecting OTP binary for CHIP Version 1
[ 25.940143]
[ 25.940143] Second otp download Param 10000
[ 30.625866] ol_ath_download_firmware : OTP download and Execute is good
[ 30.693814]
[ 30.693814] FIRMWARE : Beeliner CHIP Version 1
[ 30.774757] ol_swap_seg_alloc: Successfully allocated memory for SWAP size=13 1072
[ 30.872071] Swap: bytes_left to copy: fw:16; dma_page:41835
[ 30.928116] Swap: wrong length read:0
[ 30.972071] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 89237 Tar get address 417628
[ 31.078725] scn=ea7c0480 target_write_addr=417628 seg_info=ef5bb810
[ 31.152514] ol_transfer_swap_struct:Code swap structure successfully download ed for bin type =2
[ 31.257731] bin_filename=AR900B/hw.2/athwlan.bin swap_filename=/lib/firmware/ AR900B/hw.2/athwlan.codeswap.bin
[ 32.466822] ol_ath_attach() Download FW.
[ 32.534301] ol_ath_attach() HT Create .
[ 32.604279] ol_ath_attach() HIF Claim.
[ 32.644361] ol_ath_attach() BMI Done.
[ 32.681568] ol_ath_attach() WMI attached. wmi_handle ea850000
[ 32.751358] +HWT
[ 32.774914] CE_recv_buf_enqueue 823 Populate last entry 512 for CE 5
[ 32.849140] CE_recv_buf_enqueue 832 CE 5 wi 511 dest_ptr 0x6b99c040 nbytes 0 recv_ctxt 0xeac81f00
[ 32.955670] Target:c3cfc000 HTC Service:0x0001, ULpipe:0 DLpipe:1 id:0 Ready
[ 33.039768] -HWT
[ 33.061949]
[ 33.061949] <=== cfg max peer id 1056 ====>
[ 33.129646] Target:c3cfc000 HTC Service:0x0300, ULpipe:4 DLpipe:5 id:1 Ready
[ 33.213839] HTC Service:0x0300 ep:1 TX flow control disabled
[ 33.283317] CE_pkt_dl_len_set CE 4 Pkt download length 64
[ 33.346235] ol_txrx_pdev_attach: 1424 tx desc's allocated ; range starts from ea260000
[ 33.441174] Target:c3cfc000 HTC Service:0x0100, ULpipe:3 DLpipe:2 id:2 Ready
[ 33.527147] HTC Service:0x0100 ep:2 TX flow control disabled
[ 33.620087] wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event
[ 33.688909] host/RAM_fw Build Ver Mismatch: H:0x2F, F:0x37 !
[ 33.757638] num_rf_chain : 00000004
[ 33.799312] ht_cap_info: : 0000085b
[ 33.840987] vht_cap_info : 339a79b2
[ 33.882630] vht_supp_mcs : 0000ffea
[ 33.924304] ol_ath_service_ready_event: tt_support: 1
[ 33.984723] Peer Caching Enabled ; num_peers = 529, num_active_peers = 67 num _tids = 134, num_vdevs = 17
[ 34.098281] idx 0 req 1 num_units 0 num_unit_info 2 unit size 1296 actual un its 530
[ 34.192377] idx 1 req 2 num_units 1 num_unit_info 4 unit size 256 actual uni ts 68
[ 34.283723] idx 2 req 3 num_units 1 num_unit_info 4 unit size 1024 actual un its 68
[ 34.376444] idx 3 req 4 num_units 1 num_unit_info 4 unit size 4096 actual un its 68
[ 34.469290] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual u nits 35
[ 34.562917] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual un its 1
[ 34.654545] idx 6 req 5 num_units 0 num_unit_info 2 unit size 1860 actual un its 530
[ 34.748703] chunk 0 len 686880 requested ,ptr 0x6b000000
[ 34.813901] chunk 1 len 17408 requested ,ptr 0x6c120000
[ 34.878475] chunk 2 len 69632 requested ,ptr 0x6b7e0000
[ 34.943080] chunk 3 len 278528 requested ,ptr 0x6b100000
[ 35.008684] chunk 4 len 107520 requested ,ptr 0x6c140000
[ 35.074320] chunk 5 len 6144 requested ,ptr 0x6bc68000
[ 35.137863] chunk 6 len 985800 requested ,ptr 0x6b200000
[ 35.257107] wmi_ready_event_rx: WMI UNIFIED READY event
[ 35.309403] ol_ath_connect_htc() WMI is ready
[ 35.361480] ol_ath_set_host_app_area TODO
[ 35.409434] target uses HTT version 2.1; host uses 2.1
[ 35.414464] ol_ath_attach() connect HTC.
[ 35.414464] ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeS elect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0.
[ 35.414526] ol_ath_phyerr_attach: called
[ 35.414589] OL Resmgr Init-ed
[ 35.414589] acfg_attach: 6037: Netlink socket created:ead60a00
[ 35.414620] Green-AP : Green-AP : Attached
[ 35.414620]
[ 35.414620] Green-AP : Attached
[ 35.414620] rate power table override is only supported for AR98XX
[ 35.414651] ol_if_dfs_setup: called
[ 35.414651] ol_if_dfs_attach: called; ptr=ea2cd984, radar_info=ead6bba8
[ 35.415089] ol_ath_attach() UMAC attach .
[ 35.415120] ol_ath_attach: Calling ol_if_dfs_configure
[ 35.415120]
[ 35.415120] BURSTING enabled by default
[ 35.415182] ACS not enabled
[ 35.415182] __ol_ath_attach: init tx/rx TODO
[ 35.415182] __ol_ath_attach: needed_headroom reservation 44
[ 35.417681] ol_ath_thermal_mitigation_attach: ++
[ 35.417713] ol_ath_thermal_mitigation_attach: --
[ 35.417775] PCI device id is 0040 :0040
[ 35.418025]
[ 35.418025] ol_ath_pci_configure : num_desired MSI set to 0
[ 35.418056]
[ 35.418056] Using PCI Legacy Interrupt
[ 35.418056] chip_id 9 chip_revision 1
[ 35.418306]
[ 35.418306] HIFDiagReadMem address 0x4008f8 data ead6bc00 nbytes 4
[ 35.419337]
[ 35.419337] HIFDiagReadMem address 0x401e90 data ead6bc04 nbytes 4
[ 35.421368]
[ 35.421368] HIFDiagReadMem address 0x401e94 data ead6bc08 nbytes 4
[ 35.423430]
[ 35.423430] HIFDiagReadMem address 0x401eb0 data ead6bc0c nbytes 4
[ 35.426897]
[ 35.426897] HIFDiagReadMem address 0x400900 data ead6bc0c nbytes 4
[ 35.428959]
[ 35.428959] CLOCK PLL skipped
[ 35.428959] HIF_PCIDeviceProbed: setting the target pll frac ffffffff intval ffffffff
[ 35.428959] HIF_PCIDeviceProbed: no frac provided, skipping pre-configuring P LL
[ 35.428959] HIF_PCIDeviceProbed: ar900b_20_targ_clk is not provided, skipping pre-configuring PLL
[ 35.428959]
[ 35.428959] HIFDiagReadMem address 0x4008cc data ead6bc0c nbytes 4
[ 35.431021] __ol_ath_attach: ath_attach TODO
[ 35.431021] __ol_ath_attach 1799 host_enable 0 nss_nwifi_offload 0
[ 35.431052] __ol_ath_attach: dev name wifi1
[ 35.431052] ol_ath_set_default_tgt_config : AC Minfree buffer allocation thro ugh module param (umac.ko)
[ 35.431052] OL_ACBKMinfree : 0
[ 35.431052] OL_ACBEMinfree : 0
[ 35.431052] OL_ACVIMinfree : 0
[ 35.431084] OL_ACVOMinfree : 0
[ 35.431084] ol_ath_attach() BMI inited.
[ 38.173976] FWLOG: [35855] WAL_DBGID_TX_AC_BUFFER_SET ( ol_ath_attach() BMI G et Target Info.
[ 38.174664] ol_ath_attach() TARGET TYPE: 9 Vers 0x1000000
[ 38.174664]
[ 38.174664] CE WAR Disabled
[ 38.389190] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
[ 38.454295] ol_ath_attach() configure Target .
[ 38.506466]
[ 38.506466] Target Version is 1000000
[ 38.569353]
[ 38.569353] Flash Download Address c0000
[ 38.604311] 0x3, 0x1e, 0x518, 0x518, 0x0 )
[ 38.604311] FWLOG: [35855] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x 518, 0x0 )
[ 38.604342] FWLOG: [35855] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x 518, 0x0 )
[ 38.604342] FWLOG: [35855] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x 518, 0x0 )
[ 38.973976] ol_transfer_bin_file: flash data file defined
[ 39.037644] Cal location [1]: 00004000
[ 39.082380]
[ 39.082380] Wifi1 Select OFFSET 5000
[ 39.164573] qc98xx_verify_checksum: flash checksum passed: 0x418d
[ 39.225242] ol_transfer_bin_file 2973: Download Flash data len 12064
[ 39.301749] Board extended Data download address: 0x0
[ 39.381943]
[ 39.381943] Board data initialized
[ 39.434333] Flash download ADDRESS 0xc0000
[ 39.478225]
[ 39.478225] Selecting OTP binary for CHIP Version 1
[* 39.585160] Loading sha2...
[ 39.605810]
[ 39.605810] First OTP send param 8000
[* 39.587097] Dumpping sha2...
[* 40.786972] Loading MIC cert and key
[* 40.810652] Generating key, this may take a while...
[* 42.640987] Public key portion is:
[* 42.641018] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCJ40j8XbZS9XptIr7t2LVxmPgV RcKXB3oDO1SQmS5kkTACehPVAGggmwW/3QvEItzvjobDEsO3E/eeSe60fj0NHmF5VEjhkbNCk7n2Kodr dEb1fAHPd9l8FNlNVR8p4M8InpOdOOxYK4loNAdDTNVWSUS/bnN6KpXqedkmdf9Q29dUen60lPtBj8Hi Je4TwWL2LRsXypK+LllXZHpi6ic5SN5TYPsGww+PUzgqDLPBsoLSpQ1I2NA3eP/E9oCRQo5AFO8k3phf Qam3kQAgZxa/TT0M5K3VjxADesgIigJN5ZlbvrCsrcsIoRF1Hdc7sEeXGgAzytEL2ARZXhqxgLE7 roo t@mA0ECF96CE368
[* 42.641018] Fingerprint: md5 3b:49:8b:d9:02:d5:a6:d2:7b:e5:aa:6c:c9:32:32:02
[* 42.669009] --------- skip cisco script
[ 44.288128] ol_ath_download_firmware :First OTP download and Execute is good return param 39936
[ 44.382161]
[ 44.382161] ##Board Id 7
[ 44.430021]
[ 44.430021] ##CHIP Id 1
[ 44.476975]
[ 44.476975] BOARDDATA DOWNLOAD TO address c0000
[ 44.549859] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR90 0B_CUS239_negative_pwr_offset_5G_v2_007.bin ARXXXX v=0x1
[ 44.702280] Board extended Data download address: 0x0
[ 44.775820] ol_ath_download_firmware: Using 0x1234 for the remainder of init
[ 44.854295]
[ 44.854295] Selecting OTP binary for CHIP Version 1
[ 44.960324]
[ 44.960324] Second otp download Param 10000
[ 49.645704] ol_ath_download_firmware : OTP download and Execute is good
[ 49.713683]
[ 49.713683] FIRMWARE : Beeliner CHIP Version 1
[ 49.794532] ol_swap_seg_alloc: Successfully allocated memory for SWAP size=13 1072
[ 49.891908] Swap: bytes_left to copy: fw:16; dma_page:41835
[ 49.947953] Swap: wrong length read:0
[ 49.991971] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 89237 Tar get address 417628
[ 50.098719] scn=e9780480 target_write_addr=417628 seg_info=e97cbb10
[ 50.172352] ol_transfer_swap_struct:Code swap structure successfully download ed for bin type =2
[ 50.277569] bin_filename=AR900B/hw.2/athwlan.bin swap_filename=/lib/firmware/ AR900B/hw.2/athwlan.codeswap.bin
[ 51.482193] ol_ath_attach() Download FW.
[ 51.517900] ol_ath_attach() HT Create .
[ 51.563605] ol_ath_attach() HIF Claim.
[ 51.608434] ol_ath_attach() BMI Done.
[ 51.653202] ol_ath_attach() WMI attached. wmi_handle e97e0000
[ 51.722992] +HWT
[ 51.746298] CE_recv_buf_enqueue 823 Populate last entry 512 for CE 5
[ 51.820805] CE_recv_buf_enqueue 832 CE 5 wi 511 dest_ptr 0x6af5d040 nbytes 0 recv_ctxt 0xe9c6ae00
[ 51.927303] Target:ef56f000 HTC Service:0x0001, ULpipe:0 DLpipe:1 id:0 Ready
[ 52.011402] -HWT
[ 52.033583]
[ 52.033583] <=== cfg max peer id 1056 ====>
[ 52.101249] Target:ef56f000 HTC Service:0x0300, ULpipe:4 DLpipe:5 id:1 Ready
[ 52.185504] HTC Service:0x0300 ep:1 TX flow control disabled
[ 52.254982] CE_pkt_dl_len_set CE 4 Pkt download length 64
[ 52.317869] ol_txrx_pdev_attach: 1424 tx desc's allocated ; range starts from e90a0000
[ 52.412808] Target:ef56f000 HTC Service:0x0100, ULpipe:3 DLpipe:2 id:2 Ready
[ 52.496969] HTC Service:0x0100 ep:2 TX flow control disabled
[ 52.565385] wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event
[ 52.645798] host/RAM_fw Build Ver Mismatch: H:0x2F, F:0x37 !
[ 52.714526] num_rf_chain : 00000004
[ 52.756201] ht_cap_info: : 0000085b
[ 52.797844] vht_cap_info : 339b79b2
[ 52.839518] vht_supp_mcs : 0000ffea
[ 52.881193] ol_ath_service_ready_event: tt_support: 1
[ 52.941611] Peer Caching Enabled ; num_peers = 529, num_active_peers = 67 num _tids = 134, num_vdevs = 17
[ 53.055170] idx 0 req 1 num_units 0 num_unit_info 2 unit size 1296 actual un its 530
[ 53.149390] idx 1 req 2 num_units 1 num_unit_info 4 unit size 256 actual uni ts 68
[ 53.240612] idx 2 req 3 num_units 1 num_unit_info 4 unit size 1024 actual un its 68
[ 53.333364] idx 3 req 4 num_units 1 num_unit_info 4 unit size 4096 actual un its 68
[ 53.426179] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual u nits 35
[ 53.519806] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual un its 1
[ 53.611433] idx 6 req 5 num_units 0 num_unit_info 2 unit size 1860 actual un its 530
[ 53.705592] chunk 0 len 686880 requested ,ptr 0x6a600000
[ 53.770790] chunk 1 len 17408 requested ,ptr 0x6a598000
[ 53.835363] chunk 2 len 69632 requested ,ptr 0x6a5e0000
[ 53.899968] chunk 3 len 278528 requested ,ptr 0x6a700000
[ 53.965573] chunk 4 len 107520 requested ,ptr 0x6b0c0000
[ 54.031208] chunk 5 len 6144 requested ,ptr 0x6b7f2000
[ 54.094751] chunk 6 len 985800 requested ,ptr 0x6a000000
[ 54.212027] wmi_ready_event_rx: WMI UNIFIED READY event
[ 54.264323] ol_ath_connect_htc() WMI is ready
[ 54.316432] ol_ath_set_host_app_area TODO
[ 54.364354] target uses HTT version 2.1; host uses 2.1
[ 54.369353] ol_ath_attach() connect HTC.
[ 54.369353] ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeS elect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0.
[ 54.369696] ol_ath_phyerr_attach: called
[ 54.369759] OL Resmgr Init-ed
[ 54.369759] acfg_attach: using existing sock ead60a00
[ 54.369759] Green-AP : Green-AP : Attached
[ 54.369759]
[ 54.369790] Green-AP : Attached
[ 54.369790] rate power table override is only supported for AR98XX
[ 54.369821] ol_if_dfs_setup: called
[ 54.369821] ol_if_dfs_attach: called; ptr=ea2f5984, radar_info=ead6bba8
[ 54.370571] ol_ath_attach() UMAC attach .
[ 54.370602] ol_ath_attach: Calling ol_if_dfs_configure
[ 54.370602]
[ 54.370602] BURSTING enabled by default
[ 54.370665] ACS not enabled
[ 54.370665] __ol_ath_attach: init tx/rx TODO
[ 54.370665] __ol_ath_attach: needed_headroom reservation 44
[ 54.373164] ol_ath_thermal_mitigation_attach: ++
[ 54.373195] ol_ath_thermal_mitigation_attach: --
[ 54.473758] Initializing Pktlogs for 11ac
[ 54.473789] Initializing Pktlogs for 11ac
[* 54.381037] ath_pktlog: module license 'unspecified' taints [ 55.593127] F WLOG: [55228] WAL_DBGID_TX_AC_BUFFER_SET ( kernel.
[ 55.925273] FWLOG: [55228] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x 518, 0x0 )
[ 56.021118] FWLOG: [55228] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x 518, 0x0 )
[ 56.206310] FWLOG: [55228] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x 518, 0x0 )
[* 58.530865] click-config/io-real.click:67: While configuring 'todev_nsscapwa p0 :: ToDevice':
[* 58.530865] warning: device 'nsscapwap0' is down
[* 58.554639] click-config/io-real.click:67: While configuring 'fromdev_nsscap wap0 :: FromDevice':
[* 58.554670] warning: device 'nsscapwap0' is down
[* 59.499843] chatter: While executing 'set_node :: Script':
[* 59.499906] chatter: While calling 'srcr2/disable_dsr.run true':
[* 59.499906] chatter: no 'srcr2/gw.is_disabled' write handler
[* 59.499968] chatter: no 'srcr2/es0.is_disabled' write handler
[* 59.500031] chatter: no 'srcr2/es1.[ 59.755701] wmi_dbg_cfg_send: mod[ 0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[* 59.500093] chatter: no 'srcr2/es2.is_disabled' write handler
[* 59.500156] chatter: no 'srcr2/m_es0.is_disabled' write handler
[* 59.500218] chat[ 60.116213] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg400000 00 cfgvalid[0] 00000000 cfgvalid[1] 00000000
ter: no 'srcr2/m_es1.is_disabled' write handler
[* 59.500281] chatter: no 'srcr2/m_es2.is_disabled' write handler
[* 59.500343] chatter: no 'srcr2/link0.is_disabled' write handler
[* 59.500406] chatter: no 'srcr2/link1.is_disabled' write handler
[* 59.500468] chatter: no 'srcr2/link2.is_disabled' write handler
[* 59.500531] chatter: no 'srcr2/[ 60.625773] ol_ath_set_channel set cha nnel freq 2412
control_demux/demux.is_disabled' write handler
[* 59.590284] In write handler 'run' for 'set_enabled :: Script':
[* 59.590[ 60.784317] ol_ath_set_channel: Different channel, need to restart all VAPs
315] While calling 'client_ip_table.enable_vap_to_inet 16 0':
[* 59.590315] VAP: value 16 out of range, bound 15
[ 61.056294] ol_ath_set_channel set channel freq 5180
[ 61.164323] ol_ath_set_channel: Different channel, need to restart all VAPs
[ 65.554295] ol_ath_vap_set_param: rate 1000 is not valid.
[ 71.875476] ol_ath_vap_set_param: rate 1000 is not valid.
[* 73.031583]
[* 73.031583] !!!!! {/usr/bin/capwap_brain} failed writing /click/nss_lag_control/lag_ports len 1 data: "2"
[* 73.031865]
[* 73.031865] !!!!! {/usr/bin/capwap_brain} failed writing /click/lacp/setup_aggs len 5 data: "1r 1r"
[* 73.032146]
[* 73.032146] !!!!! {/usr/bin/capwap_brain} failed writing /click/nss_lag_control/lag_config len 1 data: "1"
[* 73.032989]
[* 73.032989] !!!!! {/usr/bin/capwap_brain} failed writing /click/nss_lag_control/port_state len 16 data: "0 false -1 false"
[* 73.033302]
[* 73.033302] !!!!! {/usr/bin/capwap_brain} failed writing /click/nss_lag_control/port_state len 16 data: "1 false -1 false"
[* 73.224960]
[* 73.224960] phy_value=0: org="0x1000" phy_reg="0x1000"
Take a picture of the AP and another picture of the label with serial number and MAC address.
-Scott
-Scott
i send u all pictures.
do u have any suggestions?
I never used this AP buts still hope its works same as other cisco AP.
So to go in config Mode on Cisco LAP, you must need to enter this command "debug capwap console cli"
As in your earlier post, you told that you have 8.1.131.0 version on WLC then you don't need to upgrade image on AP.
Once AP will try to join, AP will download the image from WLC.
see this link for basics: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
If still fails to join then paste the output of these:
1. sh sysinfo from WLC
2. Complete boot-up process from AP
Don't forget to rate helpful posts
the problem is that AP doesn't provide any cli command to enter.
this AP doesn't joins WLC in same vlan.
this AP is cloud managed, its meraki AP.
I hoped that there is the option to make this AP managed by WLC after firmware upgrade. I suupose that firmware upgrade can be done by bootload upgrade or another hardware way.
That isn't a Meraki AP?  Did you buy this new or not?  That AP can either be a lightweight AP or has an image that allows it to be a Mobility Express AP.  Power off the AP and hold the mode button down and power the device back on while still holding the mode button.  Hold the mode button for 10 seconds and release. See if that defaults the AP or not. Provide the capture of the AP console while doing this also. Attach that to this thread.
-Scott
-Scott
this is the capture
[* 16.135738]
l.
kernel.
[ 17.994033]
taints kernel.
[ 18.407091]
[ 18.538300]
[ 18.630990]
[ 18.971571]
[ 19.667416]
[ 19.837269]
[ 19.899750]
[ 20.076788]
[ 20.374632]
[ 20.470696]
[ 20.594939]
[ 25.362199]
[ 25.410059]
[ 25.457606]
[ 25.834739]
[ 25.940143]
[ 30.693814]
[ 32.751358] +HWT
[ 33.039768] -HWT
[ 33.061949]
[ 35.414620]
[ 35.415120]
[ 35.418025]
[ 35.418056]
[ 35.418306]
[ 35.419337]
[ 35.421368]
[ 35.423430]
[ 35.426897]
[ 35.428959]
[ 35.428959]
[ 38.174664]
[ 38.506466]
[ 38.569353]
[ 39.082380]
[ 39.381943]
[ 39.478225]
[ 39.605810]
[ 44.382161]
[ 44.430021]
[ 44.476975]
[ 44.854295]
[ 44.960324]
[ 49.713683]
[ 51.722992] +HWT
[ 52.011402] -HWT
[ 52.033583]
[ 54.369759]
[ 54.370602]
[* 73.031583]
[* 73.031865]
[* 73.032146]
[* 73.032989]
[* 73.033302]
[* 73.224960]
// '); } function getHtmlForRedPort(){ document.writeln('\ '); } function getCpuString() { var str = document.forms[0].indiv_cpu_usage.value; document.writeln(''+str+''); } // ]]>
Is this a brand new AP or used?  I saw this because the output doesn't look right. If you purchased this brand new, I would open a TAC case and have then look at it or RMA the device. If this is not new, then you might be stuck with something that doesn't work.
When you get the prompt, can you issue a show version?
If the output is a lot, please attach it and don't paste it into the reply.
-Scott
-Scott
The pictures you sent tells me that it wasn't a brand new AP.  That looks like a beta AP to me since I have a bunch of them. I just want to clarify if they are new or did you purchase them from someone.  You probably need to purchase another AP to make it work on a WLC or as a Mobility Express AP.
I have a few 1852's and the output doesn't look close to what you have.
-Scott
-Scott
i didn't purchase this AP, i got AP from colleagues in Cisco Office.
so, the result is that this AP is beta and not useful?
