01-19-2016 03:14 AM - edited 03-17-2019 05:33 AM
After using RTMT to search for unregistered phones I find they are showing as registered. Also the phone load on Call Manager shows the device with the new phone load whereas RTMT shows the old phone load. If I browse to the device from RTMT is shows the correct firmware. I have checked this over a 2 day period and get the same inaccuracies.
01-19-2016 04:00 AM
Hi Paul,
Can you check if there is any difference after restarting the following serviceson the servers to which these phones were / are registered
- Cisco AMC Service
- Cisco RIS Data Collector
Manish
01-19-2016 05:50 AM
Hi Manish,
Thanks for the reply. I have restarted the services on all 3 servers in the cluster. No change to the output. Still getting phones showing unregistered on RTMT that are registered on CM. Not all are registered but too many for it to be of any use. I am attaching a screenshot showing the output on RTMT and from browsing to the phone. The firmware on RTMT is still showing pre firmware upgrade.
01-19-2016 05:53 AM
Hi Paul,
it's normal, RIS database is pointing on 1 server at the time, you need to select the correct CUCM server where your phone is registered and you will see.
Hope this help
David
01-19-2016 06:30 AM
Hi David,
I tried pointing RTMT to all 3 servers and get the same outcome.
Paul
01-19-2016 08:47 AM
I see that you can select "any callmanager" so, you should see the registration there. maybe you hit a bug in RTMT.
