01-21-2016 03:44 AM - edited 03-17-2019 05:35 AM
The Scenario
I am deploying a Unified Communications solution based on a Cisco BE6000 environment (which comes in a UCS C220-M4 with pre configured voice applications).
Of all those voice applications within the bundle I am only using CUCM, CUC and IM Presence.
With that in mind, in VMWare's Virtual Machine Startup and Shutdown menu, I put the three machines in the Automatic Startup option as depicted in the following picture:
The Problem
Whenever I restart my host only one of these virtual machines gets to automatically startup. The other two, even though explicitly configured as automatic, go into the Manual Startup panel. I tried with different order of servers and only the one in the first position gets elected as automatic.
VMWare is fully licensed as well.
The Versions
CIMC - 2.0(8g)
ESXi - 5.5.0 Build 2068190
CUCM - 11.0.1.20000-2
CUC - 11.0.1.20000-2
Presence - 11.0.1.10000-6
Pedro
01-21-2016 04:26 AM
Hi Pedro,
Can you check your ESXi version and apply the patch mentioned in this discussion if required to see whether that helps.
https://supportforums.cisco.com/discussion/11810196/cisco-callmanager-unity-presence-not-start-automatically-ucs-c220m2-vm
Rajan
Pls rate all useful posts
01-21-2016 04:29 AM
Also refer the below link which mentions the same issue:
https://supportforums.cisco.com/discussion/11787051/business-edition-6000-vmware-500-623860
01-21-2016 04:34 AM
Hi Rajan,
Actually, that's one of the discussions I read previously. The problem is that the recommended patch is for ESXi version 5.0.0
(ESXi 5.0.0 build-623860).
I have version 5.5.0. But still, I'll go ahead and try the latest build for this release (ESXi 5.5.0 build-3116895).
I'll update this discussion with the results of this upgrade.
Thanks Rajan.
01-21-2016 07:53 AM
for the record:
after applying the 5.5.0 build-3116895 patch the problem with the VM automatic startup was solved.
Thank you all for your help.
01-21-2016 05:39 AM
While you are looking at this issue, it might be worth pointing out that the time you have allocated for the startup/shutdown is too small..
Your CUCM pub will need atleast a good 120-360s to fully shutdown. You might want to consider increasing the time
01-21-2016 07:51 AM
Hi Ayodeji,
Thanks for your input on that. Already took it into consideration after applying the upgrade patch which, btw, solved my automatic startup problem.
