01-21-2016 05:34 AM - last edited on 03-25-2019 06:16 PM by ciscomoderator
Hi all,
does someone know if is possible to binding the management of SourceFire sw Module on an ASA5515X to a different interface than management0/0 ?
Thank you.
Mauro
01-21-2016 07:20 AM
No, it has to be the m0/0 interface. The management is not available through one of the other interfaces.
01-24-2016 02:51 AM
Yes, SFR module only binds with Management port. Could you elaborate your query about "what is the purpose of binding SFR module to any another interface?
Sunil Kumar
01-25-2016 08:40 AM
Hi, thank you for your answer.
My management network is routed by my firewall, so i can't assign the same address space to two interface.
Thank you.
Mauro
01-25-2016 11:16 AM
You don't have to assign an IP to the ASA on the management-port. You only assign an IP to the module and the ASA itself is managed in-band. That is also shown in the Quick-start guide linked above.
