01-22-2016 03:09 PM - edited 03-17-2019 05:36 AM
Hi All,
We have Cisco WS-CE500-24PC Switches that have the "Smart-Ports" enabled. Vlan 1 for Data and Vlan 10 for voice. Now the business is moving to an Avaya system but is going to use the same switches because POE. I have created a new Vlan 11 and assigned it to port 11 and plugged in a phone. The phone gets an IP from the data network and then renews and shows it received option 249 and should now ask for an IP from the dhcp server connected on vlan 11 but it never gets an address. I am wondering if I have settings incorrect on my switch that would prevent the dhcp? A copy of one of the switch configs is below. I have the phone plugged into port 11 (see differences between port 10 (Cisco Smart-Ports) and Port 11 (cleared all settings except basics). This switch is connected to a main switch, but all switches have vlan 11 added. The IP500 call server is connected to another switch.
Building configuration...
Current configuration : 26304 bytes
! THIS FILE HAS BEEN GENERATED BY THE GUI.
! ANY CHANGES TO THIS FILE MAY RESULT IN INCORRECT SWITCH BEHAVIOR.
! Last configuration change at 11:04:49 PST Thu Jan 21 2016
! NVRAM config last updated at 10:48:42 PST Thu Jan 21 2016 by local
version 12.2
no service pad
service sequence-numbers
hostname CE500_Zone_V1
no aaa new-model
clock timezone PST -8
clock summer-time PDT recurring
no system policy dhcponly server
no system policy dhcponly ap
no system policy dhcponly ipphone
no system policy dhcponly printer
no system policy dhcponly desktop
system policy access network 2
system policy access host 1
vtp mode transparent
ip subnet-zero
ip dhcp snooping vlan 1-1024
ip dhcp snooping track host
no ip dhcp snooping information option
ip dhcp snooping
mls qos map policed-dscp 18 24 26 34 40 46 to 0
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 2 2
mls qos srr-queue output cos-map queue 3 threshold 3 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 2 18
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 19 20 21 22 23 32
mls qos srr-queue output dscp-map queue 3 threshold 3 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 2 8 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 16 8 24 52
mls qos queue-set output 2 buffers 16 6 17 61
mls qos aggregate-policer business-server-router 30000000 800000 exceed-action policed-dscp-transmit
mls qos aggregate-policer critical-server-router 30000000 800000 exceed-action policed-dscp-transmit
mls qos aggregate-policer business-server 30000000 800000 exceed-action policed-dscp-transmit
mls qos aggregate-policer critical-server 30000000 800000 exceed-action policed-dscp-transmit
mls qos aggregate-policer guest-tcp-syn 1300000 8000 exceed-action policed-dscp-transmit
mls qos aggregate-policer guest-echo 415000 8000 exceed-action policed-dscp-transmit
mls qos aggregate-policer router-tcp-syn 1300000 8000 exceed-action policed-dscp-transmit
mls qos aggregate-policer router-echo 415000 8000 exceed-action policed-dscp-transmit
mls qos aggregate-policer tcp-syn 1300000 8000 exceed-action policed-dscp-transmit
mls qos aggregate-policer echo 415000 8000 exceed-action policed-dscp-transmit
no mls qos rewrite ip dscp
mls qos
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
port-channel load-balance src-dst-ip
no file verify auto
mac access-list extended nonip
permit any any 0x800 0x0
permit any any 0x806 0x0
permit any any 0x836 0x0
no mac authentication
mac authentication table version 0
spanning-tree mode rapid-pvst
vlan access-map router-port 10
action forward
match ip address 2132
vlan access-map router-port-guest-vlan 10
action forward
match ip address 2133
vlan internal allocation policy ascending
vlan 10
name Cisco-Voice
vlan 11
name Avaya-Voice
class-map match-all VoIP-Control-class
match access-group 2142
class-map match-any other-echo-class
match access-group 2149
class-map match-any guest-echo-class
match access-group 2147
class-map match-any other-tcp-syn-class
match access-group 2150
class-map match-all router-VoIP-Control-class
match access-group 2156
class-map match-any guest-tcp-syn-class
match access-group 2148
class-map match-any guest-class
match access-group 2151
class-map match-any business-eg-server-class
match access-group 2153
class-map match-any business-tcp-syn-class
match access-group 2146
class-map match-any business-in-server-class
match access-group 2158
class-map match-any critical-in-server-class
match access-group 2157
class-map match-any critical-tcp-syn-class
match access-group 2144
class-map match-any critical-eg-server-class
match access-group 2152
class-map match-any others-class
match access-group 2140
class-map match-all VoIP-data-class
match access-group 2141
class-map match-any critical-echo-class
match access-group 2143
class-map match-any business-echo-class
match access-group 2145
class-map match-all router-VoIP-data-class
match access-group 2155
policy-map guest-port-map
class other-echo-class
set dscp cs1
police aggregate guest-echo
class other-tcp-syn-class
set dscp cs1
police aggregate guest-tcp-syn
class others-class
set dscp cs1
police 30000000 800000 exceed-action drop
policy-map general-map
class VoIP-data-class
set dscp ef
police 3200000 8000 exceed-action policed-dscp-transmit
class VoIP-Control-class
set dscp cs3
police 640000 8000 exceed-action policed-dscp-transmit
class guest-echo-class
set dscp cs1
police aggregate echo
set dscp 7
class guest-tcp-syn-class
set dscp cs1
police aggregate tcp-syn
set dscp 7
class guest-class
set dscp cs1
class others-class
set dscp 7
police 30000000 80000 exceed-action policed-dscp-transmit
policy-map router-map
class router-VoIP-data-class
set dscp ef
class router-VoIP-Control-class
set dscp cs3
set dscp cs1
police aggregate router-echo
set dscp 7
set dscp cs1
police aggregate router-tcp-syn
set dscp 7
class guest-class
set dscp cs1
class others-class
set dscp 7
policy-map critical-server-map
class critical-echo-class
set dscp af41
police 415000 8000 exceed-action policed-dscp-transmit
class critical-tcp-syn-class
set dscp af41
police 1300000 8000 exceed-action policed-dscp-transmit
class critical-in-server-class
set dscp af41
police 30000000 800000 exceed-action policed-dscp-transmit
class critical-eg-server-class
set dscp af41
policy-map business-server-map
class business-echo-class
set dscp af21
class business-tcp-syn-class
set dscp af21
class business-in-server-class
set dscp af21
class business-eg-server-class
set dscp af21
interface FastEthernet1
switchport mode access
switchport voice vlan 10
switchport port-security maximum 3
switchport port-security maximum 3 vlan access
switchport port-security maximum 3 vlan voice
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
ip access-group 2103 in
service-policy input general-map
srr-queue bandwidth share 10 10 35 45
srr-queue bandwidth shape 10 0 0 0
queue-set 2
macro description cisco-ipphone
storm-control broadcast level 0.10
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet2
ip access-group 2104 in
queue-set 2
interface FastEthernet3
ip access-group 2105 in
queue-set 2
interface FastEthernet4
ip access-group 2106 in
queue-set 2
interface FastEthernet5
ip access-group 2107 in
srr-queue bandwidth share 5 5 70 20
macro description cisco-printer
interface FastEthernet6
ip access-group 2108 in
queue-set 2
interface FastEthernet7
ip access-group 2109 in
queue-set 2
interface FastEthernet8
ip access-group 2110 in
queue-set 2
interface FastEthernet9
ip access-group 2111 in
queue-set 2
interface FastEthernet10
ip access-group 2112 in
queue-set 2
interface FastEthernet11
switchport voice vlan 111
macro description cisco-other
ip dhcp snooping trust
interface FastEthernet12
ip access-group 2114 in
queue-set 2
interface FastEthernet13
ip access-group 2115 in
queue-set 2
interface FastEthernet14
ip access-group 2116 in
queue-set 2
interface FastEthernet15
ip access-group 2117 in
queue-set 2
interface FastEthernet16
ip access-group 2118 in
queue-set 2
interface FastEthernet17
ip access-group 2119 in
queue-set 2
interface FastEthernet18
ip access-group 2120 in
queue-set 2
interface FastEthernet19
ip access-group 2121 in
queue-set 2
interface FastEthernet20
ip access-group 2122 in
queue-set 2
interface FastEthernet21
ip access-group 2123 in
queue-set 2
interface FastEthernet22
ip access-group 2124 in
queue-set 2
interface FastEthernet23
ip access-group 2125 in
queue-set 2
interface FastEthernet24
ip access-group 2126 in
queue-set 2
interface GigabitEthernet1
switchport mode trunk
srr-queue bandwidth share 10 10 45 35
udld port aggressive
mls qos trust cos
macro description cisco-switch
spanning-tree link-type point-to-point
interface GigabitEthernet2
mls qos trust cos
interface Vlan1
ip address 192.168.2.208 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.2
ip http server
ip http authentication local
ip http secure-server
access-list 2131 deny ip any any
access-list 2140 permit ip any any
access-list 2141 permit ip 192.168.60.0 0.0.0.255 any dscp ef
access-list 2141 permit ip any 192.168.60.0 0.0.0.255 dscp ef
access-list 2141 permit ip 192.168.60.0 0.0.0.255 any dscp cs5
access-list 2141 permit ip any 192.168.60.0 0.0.0.255 dscp cs5
access-list 2142 permit ip 192.168.60.0 0.0.0.255 any dscp cs3
access-list 2142 permit ip any 192.168.60.0 0.0.0.255 dscp cs3
access-list 2142 permit ip 192.168.60.0 0.0.0.255 any dscp af31
access-list 2142 permit ip any 192.168.60.0 0.0.0.255 dscp af31
access-list 2143 permit icmp any any
access-list 2143 permit udp any any eq echo
access-list 2143 permit tcp any any eq echo
access-list 2143 permit udp any eq echo any
access-list 2143 permit tcp any eq echo any
access-list 2144 permit tcp any any syn
access-list 2145 permit icmp any any
access-list 2145 permit udp any any eq echo
access-list 2145 permit tcp any any eq echo
access-list 2145 permit udp any eq echo any
access-list 2145 permit tcp any eq echo any
access-list 2146 permit tcp any any syn
access-list 2149 permit icmp any any
access-list 2149 permit udp any any eq echo
access-list 2149 permit tcp any any eq echo
access-list 2149 permit udp any eq echo any
access-list 2149 permit tcp any eq echo any
access-list 2150 permit tcp any any syn
access-list 2152 permit ip any any
access-list 2153 permit ip any any
access-list 2155 permit ip any any dscp ef
access-list 2155 permit ip any any dscp cs5
access-list 2156 permit ip any any dscp cs3
access-list 2156 permit ip any any dscp af31
access-list 2157 permit ip any any
access-list 2158 permit ip any any
control-plane
line con 0
line vty 0 4
no login
length 0
line vty 5 15
no login
ntp clock-period 36028943
ntp server 192.168.2.1
end
!122F
01-22-2016 07:15 PM
Duplicate of https://supportforums.cisco.com/discussion/12757086/ce500-24-switches-and-avaya-phones-help
