01-25-2016 09:23 AM
Hello.. I have an issue in downloading a NOS file from TFTP server to my Nexus 5010. I can transfer from Nexus switch to TFTP server but reverse is failing.
the error i am getting:-
TFTP get operation failed:File not found.
Its also says that connection to server established and after that I get this error.
The similar process for router and switch is working. Bur for nexus , its failing
I am using management Port for the file transfer.
Any help would be greatly appreciated.
01-25-2016 09:24 AM
Also, i can see similar issues in past support form, but not able to find the right answer for it there in any comments.
01-28-2016 07:55 PM
I am using TFTP32 software only for file transfer.
switch# ping 192.168.1.1 vrf management -------> MY LAPTOP IP Add
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request 0 timed out
64 bytes from 192.168.1.1: icmp_seq=1 ttl=127 time=4.829 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=127 time=3.865 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=127 time=4.069 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=127 time=4.071 ms
--- 192.168.1.1 ping statistics ---
5 packets transmitted, 4 packets received, 20.00% packet loss
round-trip min/avg/max = 3.865/4.208/4.829 ms
switch#
switch#
switch# ping 192.168.1.2 vrf management --------> MY NEXUS MGMT 0 IP ADD
PING 192.168.1.2 (192.168.1.2): 56 data bytes
64 bytes from 192.168.1.2: icmp_seq=0 ttl=255 time=0.942 ms
64 bytes from 192.168.1.2: icmp_seq=1 ttl=255 time=0.385 ms
64 bytes from 192.168.1.2: icmp_seq=2 ttl=255 time=0.343 ms
64 bytes from 192.168.1.2: icmp_seq=3 ttl=255 time=0.338 ms
64 bytes from 192.168.1.2: icmp_seq=4 ttl=255 time=0.385 ms
--- 192.168.1.2 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.338/0.478/0.942 ms
Error
Message:-
switch# copy tftp: bootflash:
Enter source filename: n5000-uk9-kickstart.4.2.1.N2.1a.bin
Enter vrf (If no input, current vrf 'default' is considered): management
Enter hostname for the tftp server: 192.168.1.1
Trying to connect to tftp server......
Connection to Server Established.
switch#
if i use this tftp server to upload IOS image to router / switches,it works fine.
please check on attahced file as well.
01-27-2016 06:36 PM
Could you use tftp32 and make sure the file is in root directory.
Let me know in case if that fails.
Inayath
