B200M4 VIC 1340 with 1280 Adaptor mismatch
I have B200M3 and B200M4 servers in the same 5108 chassis. UCS 2.2.5a
B200M3 include 2 VICs : 1240 with 1280 and no faults reported
But the B200M4 include 1340 with 1280 and it give fault: Adaptor mismatch. with description: server 1/5 has invalid adaptor combination
So I think B200M4 should have 1380 to be compatible with the 1340. But I didn't find what confirm this on Cisco. So please confirm me that
Only I found the attached table and this table :
 Table 11 Supported VIC 1340/1240 and Mezzanine Adapter Configurations
Fabric Extender Compatibility
Adapter in VIC 1340/1240 Slot
Adapter in Mezzanine Slot
Ports
Reference
2208XP (PIDs UCS-IOM-2208XP, UCS-IOM2208-16FET)
2208XP
VIC 1340 or 1240
None
4 x 10 Gb
Figure 15 on page 59
2208XP
VIC 1340 or 1240
VIC 1380 or 1280
8 x 10 Gb
Figure 16 on page 60
mjafri
Hi Hythim,
Attached image have your answer. Checked the B200 M4 spec sheet, on page 24 or search with " Supported B200 M4 I/O Configurations "
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf
MJ
mjafri
Hi Hythim,
MJ
it is what I guess also as the attached table
thanks
Wes Austin
Hey Hythim,
As MJ pointed out, you would need the 1340 with the 1380 or the 1240 with the 1280.
HTH,
Wes
