01-27-2016 06:41 AM - edited 03-08-2019 03:33 AM
Hello, I have a switch
Model: WS-C3750-48PS-S
IOS version: c3750-ipbasek9-mz.122-55.SE10.bin
It continuosly resets. I downgrade to c3750-ipbasek9-mz.122-35.SE5.bin and stops the reboot. The equipment works properly
Anyone have any idea why this happens ?
Sorry but my English ir very bad.
Thanks.
This is the log output
%Software-forced reload
Preparing to dump core...
Code checksum failed--memory corruption likely% Generating 1024 bit RSA keys, keys will be non-exportable...
00:01:06 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 1A6E988
-Traceback= 1A6E988 1A6E988 25A8CA8 1A70914 1A673D8
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_2
=== Flushing messages (00:01:11 UTC Mon Mar 1 1993) ===
Buffered messages:
*Mar 1 00:00:30.509: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar 1 00:00:43.134: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 1 00:00:44.468: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to down
00:00:47: %SYS-5-CONFIG_I: Configured from memory by console
00:00:47: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
00:00:47: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
00:00:47: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
00:00:48: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
00:00:48: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 12:56 by prod_rel_team
00:00:49: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
00:00:49: %LINK-3-UPDOWN: Interface FastEthernet1/0/12, changed state to up
00:00:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/12, changed state to up
Queued messages:
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x025B5378 SRR1 = 0x00029230 SRR2 = 0x016B4324 SRR3 = 0x00021000
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000 PC = 0x01A6E988 MSR = 0x00029230 CR = 0x33000009
LR = 0x01A6E988 CTR = 0x011A5664 XER = 0xA0000056
R0 = 0x01A6E988 R1 = 0x039D5540 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x025B5378 R5 = 0x00029230 R6 = 0x00029230 R7 = 0xBEEFCAFE
R8 = 0x00000000 R9 = 0x035E0000 R10 = 0x03521D38 R11 = 0x03521BA8
R12 = 0x0001042C R13 = 0x00110000 R14 = 0x025A8BEC R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x00000000 R29 = 0x027BB7D4 R30 = 0xB2DADB14 R31 = 0x00000003
Stack trace:
PC = 0x01A6E988, SP = 0x039D5540
Frame 00: SP = 0x039D5550 PC = 0x01A6E988
Frame 01: SP = 0x039D5570 PC = 0x01A71C4C
Frame 02: SP = 0x039D5588 PC = 0x025A8CA8
Frame 03: SP = 0x039D5590 PC = 0x01A70914
Frame 04: SP = 0x00000000 PC = 0x01A673D8
01-27-2016 12:09 PM
Very strange to see a crash on a known stable IOS, 12.2(55)SE10.
Can you try 12.2(55)SE8?
01-27-2016 03:17 PM
You may have a faulty switch or faulty ram. Try to replace the switch or open a TAC case.I had a switch do something similar and i had to replace the switch. When i put a larger image image on the switch it would start rebooting. c3750-ipbasek9-mz.122-35.SE5.bin is about 8meg and c3750-ipbasek9-mz.122-55.SE10.bin is about 12meg
John
02-03-2016 02:42 PM
I have a doubts.
The switch use the memory flash only store the IOS?what else does she writes in the memory?
Thanks for helping
Gracias por la ayuda.
Sergio
02-03-2016 05:17 PM
The switch stores the IOS on flash but when the switch boots it has to load the IOS into memory. Newer IOS have more features and use more memory.
John
02-11-2016 04:06 AM
Thanks John.
