SNMP interface info is missing ...
Hi guys , Im having a strange issue here:
I want to add an interface to be graphed on my cacti monitor but it is not listed on interfaces options for the device.
After debugging snmp commands I noticed that there is not any info available for this interface.
This interface, has a name, an alias ,it is operative up and serving 400 mbps.
Al other interfaces are ok and  their info is available on snmp queries.
Any Ideas ?
Regards.
Leo.
Mine is a:
cisco ASR9K Series (Intel 686 F6M14S4) processor with 6291456K bytes of memory.
Intel 686 F6M14S4 processor at 2127MHz, Revision 2.174
ASR 9010 AC Chassis with PEM Version 2
Running:
Cisco IOS XR Software, Version 5.2.2[Default]
Copyright (c) 2014 by Cisco Systems, Inc.
The interface config is:
Interface 06/1/1
Mon Feb  1 12:19:05.781 GMT
interface TenGigE0/6/1/1
description ##CORE##
cdp
mtu 9216
ipv4 address 10.0.0.1 255.255.255.240
flow ipv4 monitor NETFLOW-FMM-IPV4 sampler NETFLOW-SAMPLER ingress
flow ipv4 monitor NETFLOW-FMM-IPV4 sampler NETFLOW-SAMPLER egress
RP/0/RSP0/CPU0:TIBA-IGW01#sh int te 0/6/1/1
Mon Feb  1 12:19:20.142 GMT
TenGigE0/6/1/1 is up, line protocol is up
  Interface state transitions: 7
  Hardware is TenGigE, address is d46d.505b.5fb1 (bia d46d.505b.5fb1)
  Layer 1 Transport Mode is LAN
  Description: ##CORE## ENLACE METROTEL EWS 1
  Internet address is 10.0.0.1/28
  MTU 9216 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 1/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 1w4d
  5 minute input rate 37183000 bits/sec, 6640 packets/sec
  5 minute output rate 66859000 bits/sec, 7864 packets/sec
     2250779096 packets input, 1357587491397 bytes, 3 total input drops
     1589 drops for unrecognized upper-level protocol
     Received 338 broadcast packets, 800581 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     3218102241 packets output, 3742884399922 bytes, 0 total output drops
     Output 0 broadcast packets, 326706 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
Philip D'Ath
