02-02-2016 09:40 AM - edited 03-10-2019 11:26 PM
We currently have a switch - ms-duncan that has been setup for TACACS and works fine. We put the same command on another switch - sw-SPARE and it does not work:
enable secret 5 $1$lyQB$OUFCNrTeluAVeH9R1Grjm0
username netadmin privilege 15 secret 5 $1$urJC$LbxLOoBdoG1064QFcjTRe1
username admin privilege 15 secret 5 $1$LGPp$QbOZQ8Ch2kpEj.tLKsp1m/
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
tacacs-server host 10.223.8.29 single-connection key CiscoCisco
tacacs-server directed-request
Here is the debug tacacs from ms-duncan:
ms-duncan#
11w5d: TPLUS: Queuing AAA Authentication request 344 for processing
11w5d: TPLUS: processing authentication start request id 344
11w5d: TPLUS: Authentication start packet created for 344(reed.vendor)
11w5d: TPLUS: Using server 10.223.8.29
11w5d: TPLUS(00000158)/0/IDLE/4383A40: got immediate connect on new 0
11w5d: TPLUS(00000158)/0/WRITE/4383A40: Started 5 sec timeout
11w5d: TPLUS(00000158)/0/WRITE: wrote entire 47 bytes request
11w5d: TPLUS(00000158)/0/READ: read entire 12 header bytes (expect 16 bytes)
11w5d: TPLUS(00000158)/0/READ: read entire 28 bytes response
11w5d: TPLUS(00000158)/0/4383A40: Processing the reply packet
11w5d: TPLUS: Received authen response status GET_PASSWORD (8)
11w5d: TPLUS: processing authentication continue request id 344
11w5d: TPLUS: Authentication continue packet generated for 344
11w5d: TPLUS(00000158)/0/WRITE/4383CA8: Started 5 sec timeout
11w5d: TPLUS(00000158)/0/WRITE: wrote entire 25 bytes request
11w5d: TPLUS(00000158)/0/READ: read entire 12 header bytes (expect 6 bytes)
11w5d: TPLUS(00000158)/0/READ: read entire 18 bytes response
11w5d: TPLUS(00000158)/0/4383CA8: Processing the reply packet
11w5d: TPLUS: Received authen response status PASS (2)
11w5d: TPLUS: Queuing AAA Authorization request 344 for processing
11w5d: TPLUS: processing authorization request id 344
11w5d: TPLUS: Protocol set to None .....Skipping
11w5d: TPLUS: Sending AV service=shell
11w5d: TPLUS: Sending AV cmd*
11w5d: TPLUS: Authorization request created for 344(reed.vendor)
11w5d: TPLUS: using previously set server 10.223.8.29 from group tacacs+
11w5d: TPLUS(00000158)/0/IDLE/4384698: got immediate connect on new 0
11w5d: TPLUS(00000158)/0/WRITE/4384698: Started 5 sec timeout
11w5d: TPLUS(00000158)/0/WRITE: wrote entire 66 bytes request
11w5d: TPLUS(00000158)/0/READ: read entire 12 header bytes (expect 18 bytes)
11w5d: TPLUS(00000158)/0/READ: read entire 30 bytes response
11w5d: TPLUS(00000158)/0/4384698: Processing the reply packet
11w5d: TPLUS: Processed AV priv-lvl=15
11w5d: TPLUS: received authorization response for 344: PASS
ms-duncan#
Here is the debug tacacs from sw-SPARE:
sw-SPARE#
Feb 2 17:17:49.477: TPLUS: Queuing AAA Authentication request 42 for processing
Feb 2 17:17:49.477: TPLUS: processing authentication start request id 42
Feb 2 17:17:49.477: TPLUS: Authentication start packet created for 42()
Feb 2 17:17:49.477: TPLUS: Using server 10.223.8.29
Feb 2 17:17:49.482: TPLUS(0000002A)/0/NB_WAIT/452B47C: Started 5 sec timeout
Feb 2 17:17:49.482: TPLUS(0000002A)/0/NB_WAIT: wrote entire 36 bytes request
Feb 2 17:17:49.482: TPLUS: Would block while reading pak header
Feb 2 17:17:49.487: TPLUS(0000002A)/0/452B47C: Processing the reply packet
Feb 2 17:17:58.437: TPLUS: Queuing AAA Authentication request 42 for processing
Feb 2 17:17:58.437: TPLUS: processing authentication start request id 42
Feb 2 17:17:58.437: TPLUS: Authentication start packet created for 42()
Feb 2 17:17:58.437: TPLUS: Using server 10.223.8.29
Feb 2 17:17:58.437: TPLUS(0000002A)/0/NB_WAIT/4165F60: Started 5 sec timeout
Feb 2 17:17:58.437: TPLUS(0000002A)/0/NB_WAIT: wrote entire 36 bytes request
Feb 2 17:17:58.437: TPLUS: Would block while reading pak header
Feb 2 17:17:58.442: TPLUS(0000002A)/0/4165F60: Processing the reply packet
sw-SPARE#
It appears that the problem is there is no username in the Authentication start packet for the sw-SPARE:
What do we need to do to fix this and get TACACS to work on sw-SPARE?
Solved! Go to Solution.
02-03-2016 01:25 PM
Can you add another statement to the configuration:
ip tacacs source-interface vlan1
The command is to specify an interface / IP address for all outgoing TACACS+ packets.
~ Jatin
02-02-2016 11:19 AM
Is sw-SPARE added as a network device on your TACACS+ server?
02-02-2016 12:24 PM
yes
02-03-2016 10:31 AM
yes
02-02-2016 11:37 AM
Can you please replace this command on sw-SPARE
With tacacs-server host 10.223.8.29 key CiscoCisco
and test again.
~ Jatin
02-03-2016 05:35 AM
I replaced the command with the one suggested above. The results were the same:
sw-SPARE#
Feb 3 13:33:15.679: TPLUS: Queuing AAA Authentication request 48 for processing
Feb 3 13:33:15.679: TPLUS: processing authentication start request id 48
Feb 3 13:33:15.679: TPLUS: Authentication start packet created for 48()
Feb 3 13:33:15.679: TPLUS: Using server 10.223.8.29
Feb 3 13:33:15.679: TPLUS(00000030)/0/NB_WAIT/43F43A0: Started 5 sec timeout
Feb 3 13:33:15.684: TPLUS(00000030)/0/NB_WAIT: socket event 2
Feb 3 13:33:15.684: TPLUS(00000030)/0/NB_WAIT: wrote entire 36 bytes request
Feb 3 13:33:15.684: TPLUS(00000030)/0/READ: socket event 1
Feb 3 13:33:15.684: TPLUS(00000030)/0/READ: Would block while reading
Feb 3 13:33:15.684: TPLUS(00000030)/0/READ: errno 254
Feb 3 13:33:15.684: TPLUS(00000030)/0/43F43A0: Processing the reply packet
sw-SPARE#
Any other thoughts?
02-03-2016 06:27 AM
I guess errno 254 means that tacacs packet is sourced with a different ip address then what you have added on the tacacs server. can you share "show ip int bri" output from the device in question and also what interface / ip address have you configured on Tacacs.
~ Jatin
02-03-2016 07:39 AM
sw-SPARE#sh ip int bri
Vlan1 172.19.4.9 YES NVRAM up up
Vlan160 10.249.160.11 YES DHCP up up
Vlan240 10.249.240.11 YES DHCP up up
FastEthernet0 unassigned YES NVRAM administratively down down
GigabitEthernet1/0/1 unassigned YES unset down down
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset down down
GigabitEthernet1/0/4 unassigned YES unset down down
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset down down
GigabitEthernet1/0/7 unassigned YES unset down down
GigabitEthernet1/0/8 unassigned YES unset down down
GigabitEthernet1/0/9 unassigned YES unset down down
GigabitEthernet1/0/10 unassigned YES unset down down
GigabitEthernet1/0/11 unassigned YES unset up up
GigabitEthernet1/0/12 unassigned YES unset down down
GigabitEthernet1/0/13 unassigned YES unset down down
GigabitEthernet1/0/14 unassigned YES unset down down
GigabitEthernet1/0/15 unassigned YES unset down down
GigabitEthernet1/0/16 unassigned YES unset down down
GigabitEthernet1/0/17 unassigned YES unset down down
GigabitEthernet1/0/18 unassigned YES unset down down
GigabitEthernet1/0/19 unassigned YES unset down down
GigabitEthernet1/0/20 unassigned YES unset down down
GigabitEthernet1/0/21 unassigned YES unset administratively down down
GigabitEthernet1/0/22 unassigned YES unset down down
GigabitEthernet1/0/23 unassigned YES unset down down
GigabitEthernet1/0/24 unassigned YES unset up up
GigabitEthernet1/0/25 unassigned YES unset down down
GigabitEthernet1/0/26 unassigned YES unset down down
GigabitEthernet1/0/27 unassigned YES unset down down
GigabitEthernet1/0/28 unassigned YES unset down down
sw-SPARE#
TACACS
Network Configuration --> Network Device Group --> Spare Test -->
AAA Client Hostname --> Spare Switch --> AAA Client IP Address --> 172.19.4.9
02-03-2016 01:25 PM
~ Jatin
02-12-2016 09:59 AM
That worked! So, why do you have to specify an interface for the outgoing TACACS packets here? Never had to do that before.
02-12-2016 10:38 AM
This command is especially useful in cases where the NAD has many interfaces and you want to ensure that all TACACS+ packets from a particular NAD have the same IP address.
~ Jatin
04-18-2018 12:24 AM
I had some problem too. I received in log and ISE next messages:
Apr 18 06:36:29.639: TPLUS(000001A2)/0/READ: Would block while reading
Apr 18 06:36:29.639: TPLUS(000001A2)/0/READ: socket event 1
Apr 18 06:36:29.639: TPLUS(000001A2)/0/READ: read 0 bytes
Apr 18 06:36:29.639: TPLUS(000001A2)/0/READ: errno 254
Apr 18 06:36:29.639: TPLUS(000001A2)/0/131A1114: Processing the reply packet
Message Text | Failed-Attempt: TACACS+ Request dropped |
Failure Reason | 13017 Received TACACS+ packet from unknown Network Device or AAA Client |
I solved this problem by removing this device on the ISE and created it again.
But usually that occurs when on device config do not have command
11-14-2018 04:17 AM
Thank you. This worked for me.
02-14-2023 02:34 PM
This worked for me as well. Our would work sometimes and sometimes not. Cant believe I didn't think of this, but it makes perfect sense. ISE is configured with just a single IP from this device, so gotta make sure it all comes from the same IP.
