02-03-2016 08:21 AM - edited 03-08-2019 04:27 AM
Need to enable LLDP on a 3750 switch, but command will not take and receive, "invalid input detected". Reason LLDP needs to be turned is for 4 Meraki MR34 access points. MR34 is running in low power mode and Meraki support suggested enabling LLDP (lldp run from confg t mode), but it is not working. Also tried to enable LLDP on individual interfaces, but those commands will not work either. That is as far as Meraki will take it so hoping this support community can help. 3750 is running IOS version c3750-ipservicesk9-mz.122-25.SEE4.
According to 3750 switch Power for the MR34s is 15.4W
Interface Admin Oper Power Device Class Max
(Watts)
Fa1/0/1 auto off 0.0 n/a n/a 15.4
Fa1/0/2 auto off 0.0 n/a n/a 15.4
Fa1/0/3 auto on 15.4 MR34 4 15.4
Fa1/0/4 auto on 15.4 MR34 4 15.4
Fa1/0/5 auto on 15.4 MR34 4 15.4
According to Meraki dashboard power consumption
Thanks in advance for any help provided.
Brett
Solved! Go to Solution.
02-03-2016 08:35 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Believe you need a newer IOS version for LLDP support. (As Cisco has had CDP, they're a bit late supporting LLDP.)
02-03-2016 10:51 AM
Have a look at Table 6 of the c3750 12.2(46)SE Release Notes:
Link Layer Discovery Protocol (LLDP) and LLDP Media Endpoint Discovery (LLDP-MED: 12.2(37)SE
Link Layer Discovery Protocol Media Extensions (LLDP-MED): 12.2(40)SE
Rolf
02-03-2016 08:35 AM
Disclaimer
Posting
02-03-2016 10:51 AM
Rolf
