02-03-2016 10:12 AM - edited 03-05-2019 03:15 AM
I have a customer that wants to add a couple of small 4 port switches into their existing network to expand a couple of offices temporarily. In their case, they have a pair of linked 2960X PoE switches that they would like to attach to.
A test by one of their people appears to show that this will not work - either the switch or something else is preventing the cheap switch from connecting to the network. Is this the case? If so, is there a Cisco alternative to work with to make this happen? They will be doing a lot of remodeling, and the ability to add and remove small switch blocks would be a big help while desks are being moved.
02-03-2016 10:18 AM
Hello Bruce,
adding unmanaged small cheap switches to a network is always a bad idea. I have seen customers desperate because after one year one of this small boxes created a bridging loop that blocked the whole campus network.
I don't know why it is not possible to connect the small switches to the 2960-X switches but I recommend to do not do it.
This is my opinion based on my work experience.
Hope to help
Giuseppe
02-03-2016 12:08 PM
Hello, brucesackett.
Can you show configuration of the 2960-X ports where they trying to connect this small switches?
And I will agree with Giuseppe Larosa. It really is a bad idea to connect not manageble switches to the network. If you configure 2960-X right the loop will not breake all your network but it will turn off one or 2 ports of the 2960-X switch.
Best Regards.
