02-04-2016 10:58 PM - edited 03-01-2019 08:11 AM
Hello experts,
I have a testbed configuration with Nexus 7700 - F3 (NxOS 6.4 and latest 7.2, too) and try to configure a simple xconnect. The AC and MPLS interface are on the same F3 card.
Everything seems OK control-plane-wise but the PW doesn’t come up. The 7K is connected directly to an ASR1k. The configuration is done in a simple not-mixed VDC.
The question is - is this a supported topology (if so, what am I am missing in config)?
Thanks, kind regards,
Eduard
MPLS Interface
CORE-INTER_DC# show mpls int detail
Interface Ethernet1/43:
ldp enabled
MPLS operational
Label space id 0x10000001
MPLS sub-layer Ethernet1/43-mpls layer(0x26000001)
CORE-INTER_DC# show mpls l2transport binding
Destination Address: 2.2.2.2,VC ID: 201
Local Label: 18
Cbit: 1, VC Type: Ethernet, GroupID: 0
MTU: 1500, Interface Desc: Vlan201
VCCV: CC Type: RA [2], TTL [3]
CV Type: LSPV [2]
Remote Label: 23
Cbit: 1, VC Type: Ethernet, GroupID: 12
VCCV: CC Type: CW [1], RA [2], TTL [3]
CV Type: LSPV [2]
CORE-INTER_DC# show int ethernet 1/42.21
Ethernet1/42.21 is up
admin state is up, Dedicated Interface, [parent interface is Ethernet1/42]
Hardware: 1000/10000 Ethernet, address: 8c60.aaaa.aaaa (bia 188b.aaaa.aaaa)
Description: Vlan201
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation 802.1Q Virtual LAN, Vlan ID 201, medium is broadcast
Port mode is routed
Auto-mdix is turned off
EtherType is 0x8100
L3 in Switched:
ucast: 0 pkts, 0 bytes - mcast: 0 pkts, 0 bytes
L3 out Switched:
l2vpn xconnect context TEST
member Ethernet1/42.21
member pseudowire201 2.2.2.2 201 encapsulation mpls
CORE-INTER_DC# show l2vpn service xconnect all detail
Legend: St=State XC St=State in the L2VPN Service Prio=Priority
UP=Up DN=Down AD=Admin Down IA=Inactive
SB=Standby HS=Hot Standby RV=Recovering NH=No Hardware
m=manually selected
Interface Group Encapsulation Prio St XC St
VPWS name: TEST, State: DN
Eth1/42.21 Eth1/42.21:201(Eth VLAN) 0 UP DN
Interworking: none
pw201 2.2.2.2:201(MPLS) 0 DN DN
Local VC label 18
Remote VC label 23
port-profile:
CORE-INTER_DC# show l2vpn atom vc pseudowire 201 detail
pseudowire201 is down, VC status is down PW type: Ethernet
Create time: 00:09:10, last status change time: 00:08:59
Last label FSM state change time: 00:08:58
Destination address: 2.2.2.2 VC ID: 201
Output interface: Ethernet1/43, imposed label stack {23}
Preferred path: not configured
Default path: active
Next hop: 192.168.10.2
Member of xconnect service TEST
Associated member Eth1/42.21 is up, status is up
Interworking type is Like2Like
Signaling protocol: LDP, peer 2.2.2.2:0 up
Targeted Hello: 1.1.1.1(LDP Id) -> 2.2.2.2, LDP is UP
Graceful restart: configured and not enabled
Non stop routing: not configured and not enabled
PWid FEC (128), VC ID: 201
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : activating, LruRruD
Local dataplane status received : DOWN(pw-tx-fault)
BFD dataplane status received : Not sent
BFD peer monitor status received : No fault
Status received from access circuit : No fault
Status sent to access circuit : DOWN(pw-rx-fault)
Status received from pseudowire i/f : No fault
Status sent to network peer : DOWN(pw-tx-fault)
Status received from network peer : No fault
Adjacency status of remote peer : No fault
Sequencing: receive disabled, send disabled
Bindings
Parameter Local Remote
Label 18 23
Group ID 0 12
Interface Vlan201 Vlan201
MTU 1500 1500
Control word on (configured: autosense) on
PW type Ethernet Ethernet
VCCV CV type 0x02 0x02
LSPV [2] LSPV [2]
VCCV CC type 0x06 0x07
RA [2], TTL [3] CW [1], RA [2], TTL [3]
Status TLV enabled supported
Rx Counters
0 input transit packets, 0 bytes
0 drops, 0 seq err
Tx Counters
0 output transit packets, 0 bytes
0 drops
CORE-INTER_DC(config-if)#
CORE-INTER_DC(config-if)# show mpls l2transport vc detail
Local interface: Eth1/42.21 up, Eth VLAN up
Destination address: 2.2.2.2, VC ID: 201, VC status: down
Last error: MPLS dataplane reported a fault to the nexthop
Create time: 00:04:22, last status change time: 00:00:16
Last label FSM state change time: 00:00:16
Last local dataplane status rcvd: DOWN(pw-tx-fault)
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: DOWN(pw-rx-fault)
Last local PW i/f circ status rcvd: No fault
Last local LDP TLV status sent: DOWN(pw-tx-fault)
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 18, remote 23
Group ID: local 0, remote 12
MTU: local 1500, remote 1500
Remote interface description: Vlan201
Control Word: On (configured: autosense)
VC statistics:
transit packet totals: receive 0, send 0
transit byte totals: receive 0, send 0
transit packet drops: receive 0, seq error 0, send 0
CORE-INTER_DC# show mpls ldp neighbor detail
Peer LDP Ident: 2.2.2.2:0; Local LDP Ident 1.1.1.1:0
TCP connection: 2.2.2.2.17610 - 1.1.1.1.646
Password: not required, none, in use
State: Oper; Msgs sent/rcvd: 34/37; Downstream; Last TIB rev sent 14
Up time: 00:19:51; UID: 2; Peer Id 1
LDP discovery sources:
Ethernet1/43; Src IP addr: 192.168.10.2
holdtime: 15000 ms, hello interval: 5000 ms
Targeted Hello 1.1.1.1 -> 2.2.2.2, active, passive;
holdtime: infinite, hello interval: 10000 ms
Addresses bound to peer LDP Ident:
192.168.4.100 172.20.0.103 2.2.2.2 192.168.2.200
192.168.10.2
Peer holdtime: 180000 ms; KA interval: 60000 ms; Peer state: estab
Clients: Dir Adj Client
Capabilities Sent:
[Dynamic Announcement (0x0506)]
[Typed Wildcard (0x050b)]
Capabilities Received:
[Typed Wildcard (0x050b)]"
