Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929199members
1243342discussions
Community Activity
Controle planes in vPC
I have a doubt that how two controle planes will work in vPC and what are the real time scenarios to see the two controle planes vPC. Can any one help me to understand exactly how two controle planes works compared with single controle planes in VSS ...
ESATshoot by Level 1
  • 0 Views
  • 0 replies
Resolved! NGFW Sizing
Hi,Please I need an advise to determine the right NGFW based on the below requirements:- Each NGFW physical appliance should provide minimum of 240 Gbps Firewall throughput.- Each NGFW physical appliance must support minimum of 850,000 new TCP connec...
ACI Update
  Hey everyone, Hope you're all doing great! I'm looking to update my ACI APIC, but I'm a bit lost on where to start. My current version is pretty ancient and it's never been updated. Here's what I've got:     Role Pod Node N...
Pseudowire over XRd not working?
Hi, We´ve been using XRd as a way to do integration testing with our autoprovisioning platform using gnmi.This works great.However I'm currently trying to do end to end testing of the whole solution with actual traffic forwarding across the finished ...
SA2 by Level 1
  • 420 Views
  • 24 replies
Configuring Type 6 Passwords in IOS XE
HistoryRequirementsConfiguration StepsManaging the KeysChanging the PasswordVerificationThese need to be reviewed \ changed.These are safe to use.FAQReferences History Traditionally Cisco has used several different methods for storing passwords and ...
Tim Glen by Cisco Employee
  • 41257 Views
  • 17 replies
  • 28 Helpful votes
com.sun.jersey.api.client.ClientHandlerException
Hi ,need some help on this error message.The error was: A built-in element encountered an exception of typecom.sun.jersey.api.client.ClientHandlerException. The root cause was: com.sun.jersey.api.client.ClientHandlerException: java.net.SocketTimeoutE...
kavle by Level 1
  • 82 Views
  • 3 replies
Site-to-site vpn failover causing memory spike in spoke sites
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
PikaPika by Level 1
  • 172 Views
  • 11 replies
AP issue
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS  Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
Call Transfer not showing originator
I have a real estate office with a receptionist and a realtor. The realtor phone is set for CallFwdAll to their cell phone. The customer calls into the main number. Then transfer the call to the realtor. The call then get's forwarded to the reatlor's...
