02-08-2016 12:28 AM - edited 03-17-2019 05:47 AM
i'm trying to restore call manager server from backup files, (cucm,cup and cuc). according to the procedures, but can find any *.tar file available to restore from.
1. backup device is configured and can access the SFTP server.
2. Files are available on SFTP.
attached print screen.
thx.
Solved! Go to Solution.
02-08-2016 01:53 AM
You need to look for the file named date-hostname_drfcomponent .Open it in notepad and can get the version.
regds,
aman
02-08-2016 12:35 AM
what is CUCM version u are using?
Are the backup files lying in same path [directory] where sftp is referencing to?
regds,
aman
02-08-2016 01:36 AM
9.1.1.20000-5.
Yes, backup device is routed to the correct path.
02-08-2016 01:39 AM
Was the backup taken from same 9.1.1.20000-5 version? If its a different version then it will not work.
Manish
02-08-2016 01:45 AM
anyway to identify the version that backup was created?
02-08-2016 01:53 AM
regds,
aman
02-08-2016 02:26 AM
getting the error below:
Failed to initiate restore. : Component tar files are missing from backup location. Please confirm all valid tar files are present before restore operation.
where i can find that file. i was upload all files from BKP
02-08-2016 02:31 AM
Seems few backup files are missing. Can u share snapshot of what all files do you have in backup?
regds,
aman
02-08-2016 02:38 AM
02-08-2016 02:55 AM
This does not look like CUCM backup files as I see only CUPS component here in the screenshot. You are trying to restore CUCM server or a CUPS server ?
02-08-2016 03:24 AM
hi,
Can u explain in detail?
Whether the new IMP server has built has same IP/DNS/credentials as the old one?
You are trying to restore the backup taken in Oct. 2015 on same version of new IMP server?
How many nodes you have for IMP and whether all are UP?
regds,
aman
02-08-2016 05:46 AM
one cup server, after restoring I'm getting "data base communication error", while all network configuration are the same for 100%...
trying to restart DB with no luck.
02-08-2016 06:58 AM
what was the issue? How u restored the backup?
can u share the utils dbreplication runtimestate from Presence ?
regds,
aman
02-09-2016 02:51 AM
