02-08-2016 07:43 AM - edited 03-08-2019 04:31 AM
I can ping an IP address but not traceroute. When I am trying to traceroute getting below response. Could anyone assist me to resolve it.
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
Nilesh
02-08-2016 10:48 AM
Difficult to say without knowing what devices are between the source and destination IP.
Ping simply sends an ICMP packet to the destination IP and gets a response back.
Traceroute on the other hand sends ICMP packets with increasing TTLs so each L3 device along the path has to send a response to source IP.
So it could be acls, firewalls, router configurations etc. that are stopping the traceroute from working correctly.
Jon
02-09-2016 03:00 AM
Cisco is using UDP for traceroute actually.
So if the source device would be a Cisco switch, e.g., there could be an ACL or FW rule permitting ICMP echo (=Ping) but denying UDP (=traceroute) causing the symptoms?
Best regards,
Milan
02-10-2016 07:33 AM
Hi Jon,
There is no such access-list on router but I am not sure about the firewall, if it would be blocking.
Nilesh
02-08-2016 01:50 PM
Hello
Following on from Jons response- On the router try and either disable IP domain-lookup or use the numeric command
By default traceroute performs dns resolution
traceroute xxxxxx numeric
Res
Paul
02-10-2016 07:30 AM
Hi Paul,
I tried that but it did not work.
Nilesh
07-13-2018 06:30 AM
Even if ICPM can be inspected and you can ping to the internet but when you do a trace to the same IP as you ping the firewall will block the returning traffic, I had the same problem until I allow icmp from any to the internal IPs as traffic hit the outside interface then everything worked.
