Hi All,
I am trying to configre CA certificate for VPN users to be able to connect using certificate on smartcard.
I have added our local MS Certificate authority to crypto ca trustpoint and configured "Accept certificates issued by this CA". So far so good, but CRL doesn't work as expected.
1)ASA was not able to parse CRL url path from certificate (workaround is to configure static URL)
2)Revocation check tab - here is the biggest problem
-Check certificates for revocation -> [Set for CRL only]
-Consider certificate valid if revocation information cannot be retrieved [checked]
"Consider certificate valid" ignores CRL list. I have placed user certificate to Revoked certificates and published CRL. When this checkbox was not checked, I could not log (Certificate chain failed validation. Certificate is revoked. ). After making this checkbox active, user with the same certificate could log without problem.
I think this is bug. The "consider certificate valid" should allow users to login only when CRL path is unavailable. If I do not want to check CRL, I configure "Do not check certificates for revocation".
Here is relevant config part:
crypto ca trustpoint ASDM_TrustPoint54
revocation-check crl
enrollment terminal
validation-usage ssl-client
no accept-subordinates
crl configure
policy static
url 1 http://local.ca/CertEnroll/localCA.crl
cache-time 1
no protocol ldap
no protocol scep
