URI dialing with Jabber for Android and Iphone
maqsood ahmed
dear Experts !
Can we do  URI dialing with  Jabber for Android and  Iphone  ?
all the documents in cisco.com  says about J4W , but the jabber for android feature  also say it can be done ,,,but how ,,,can anybody share some PDF or  know-how document.
6 Replies 6
URI for  Jabber for windows is working  by editing the jabber-config.xml file .,...
how can i apply  jabber-config.xml   for  android / iphone  individually ....
i want jabber for android should able to dial in thru uri ...
The same way you configure a .xml which is not jabber-config.xml on Windows, it's covered in the documentation.
java
if this helps, please rate
hi  Jamie !
below is partial list of config-xml file from tftp server ,, uri dialing works with  JabberforWindows,,,but not for  android and iphone  jabber ...
i could not understand u r comments :)  or  Pls can u elaborate or guide me to it !
- <Policies>
<Video_Disabled>false</Video_Disabled>
<EnableSIPURIDialling>true</EnableSIPURIDialling>
<DirectoryURI>mail</DirectoryURI>
</Policies>
- <Directory>
<DirectoryServerType>UDS</DirectoryServerType>
- <Directory>
I think we can dial it thru favorites !  first add the contacts to favorites,,once u are in favorites,,there is  phone handset icon on top left ,,,just  tab that icon ,,u will see options to dial......mail-id will be there,,,just select and dial ...
is there any other way...pls let us know . :)
My jabber-config.xml has:
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
 <Policies>
URI dialing works for Windows & Mac clients, but not Android or iOS device.
GTG
Please rate all helpful posts.
