SFP modules to use on Catalyst 3650-24TD-E
Answered Question
Feb 9th, 2016
We plan to buy a Catalyst 3650-24TD-E switchs, and I would like to be sur to buy the right SFP and SFP+ modules for it. As you know this Switch's model supports 2 1-Gigabit SFP and 2 10-Gigabit SFP+ uplink ports.
We have alrady other catalyst 2960 switchs with GLC-SX-MM SFP modules for the uplink connections.
which SFP/SFP+ models do you recommand?
Best regards,
Correct Answer by Leo Laohoo about 1 year 6 months ago
GLC-SX-MMD
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Tue, 02/09/2016 - 04:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
GLC-SX-MMD
Leo Laohoo Tue, 02/09/2016 - 13:54
  • Hall of Fame,
    2017 LAN, Wireless
and for the SFP+ modules ?
If the 2960 is only using GLC-SX-MM then the 3650 cannot use SFP-10G-SR to link the two of them.  The modules need to be of the same speed and the same wavelength.
zineeddine.b Wed, 02/10/2016 - 04:52
We will buy 2 3650 that will be a about 100m from each other. So it's better to connect them using 10G SFP I think!
