02-10-2016 06:14 AM - edited 03-17-2019 05:49 AM
We are having Site A & Site B ...
On site A Extns are configured as 912261820XXX where PRI range 022 61720XXX - 022 61820YYY is in used
On site B Extns are configured as 912233409XXX where PRI range is 022 33409XXX - 022 33409YYY
Suppose PRI On site A down can users from Site B will Call to the Site A...or we require to create the extra configuration
02-10-2016 10:33 PM
02-11-2016 12:59 AM
Hello Vikas, Both side on the same cluster
02-11-2016 01:20 AM
Hi Vijay,
Thanks for giving me new name again :)
I apologize I have problem in understanding your exact question. If both sites are in same cluster and have dedicated PRI at each site, how does it matter for call going from one site to other on IP during PRI outage?
Please let me know if I am missing anything, else please clarify the same.
- Vivek
02-11-2016 01:45 AM
Hello Vivek,
1. Both the sides are in same cluster.
2. we configured the DID range for off net calls..on each of the site...
3. the DN we configure for the users in each site is respective with the DID range.
My query is if PRI DOWN from any of the site ...will both the site can call each other as they are in same cluster
02-11-2016 01:50 AM
Hi Vijay,
Irrespective whether these sites are in same or different cluster, as long as you are not using PRI for calls between these two sites (I am considering you will use WAN for inter-site calling), there is no impact of PRI status on these calls.
However if you are translating DN to DID number and then using PRI for inter-site calling (call is going through PSTN), then definitely you won't be able to reach other site when PRI is down. I hope that is not the case you are asking for.
- Vivek
