Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919101members
1223177discussions
Community Activity
how to modify TTL to less values at routers?
Assume that there are three router type devices outside firewall, and one core switch router behind one layer firewalland I would like to hide the router hop of core switch router from traceroute how to modify TTL to less values at router at the most...
Maivakov by Level 1
  • 41 Views
  • 2 replies
Refreshing APIC-L2's with APIC-L4's
Hello all,I'm trying to make sure I understand the procedure for refreshing our current L2 APIC's with our new L4 APIC's.Currently our fabric is running 5.2(4) , and the new L4 APIC's require either 5.3 or 6.0.5 (which has just come out and is what w...
vv0bbLeS by Level 1
  • 1 Views
  • 0 replies
Resolved! Flexconnect on wlc 9800
Hi,We have a pair of 9800s in HA/SSO. About to migrate our APs from 8540 to 9800. As im recreating our SSIDs to the new 9800s, we cant get the one flexconnect SSID to work. The 4 centrally switched SSIDs work as expected. I have followed the various ...
trondaker by Level 1
  • 188 Views
  • 6 replies
Resolved! CML 2.6.1 NXOS Issue with Intervlan Routing
Good day, I am using CML 2.6.1, have a simple topology built, with two hosts, and a single Nexus 9K device. Both hosts are connected to the device. The configurations are default, except the following:- There are 2 vlans on the nexus, vlan 2 and vlan...
Raid3n by Level 1
  • 123 Views
  • 3 replies
Tacacs server configuration problem
Greeting everyone! There is a little problem with configuring tacacs server on ws-2950-24 model switch. The rest switches we have are 2960 series, also 3xxx series and others, more modern versions. We always configured tacacs server this way:tacacs-s...
How to Start WebEx minimized
Hi,We are in second half of 2022 now and I see there still is no way I can make Cisco WebEx start minimized with Windows.It just pops up soon as my computer starts and it's far too intrusive. It should start in the background and sit idle in the task...
SIP REGISTER fails with 580 but server has no logs
I am trying to send a SIP REGISTER and it fails with 580.I cannot find out how to determine what is being denied. ie: what i am sending wrong that could result in a 580is there a way in CUCM to find in a  log file somewhere what might be wrong with t...
r0nh by Level 1
  • 374 Views
  • 14 replies
WSA Transparent WCCP Options (FTD or 4500X Switch WCCP)?
We are migrating from our Older Cisco ASA Firewalls to Cisco FTD 2140's.  We currently are using WCCP on the ASA's for Transparent Proxy with our WSA Virtual Appliance under VMWare.  I was just going to migrate WCCP Configurations to the FTD 2140's w...
npt by Level 1
  • 130 Views
  • 4 replies
