CSCux29978 on systems not configured for IKE
awysocki
For firewalls which do not have Ikev1 or v2 enabled/configured, could the remote code still be executed and either force the reboot or allow for remotely executing code?
rvarelac
Level 7
Level 7
Hi awysocki
The documentation states you need either a Site-to-Site tunnel running Ikev1 or ikev2 , or a remote connection with ipsec technologies. If you don't have any of those technologies the exploit can't be executed.
You can check if the IPSec is enabled with the command:
 ciscoasa# show running-config crypto map | include interface
    crypto map outside_map interface outside
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20160210-asa-ike
Hope it helps
-Randy-
rvarelac
Level 7
Level 7
Hi awysocki
Hope it helps
-Randy-
Thanks. I apparently skipped that section when reading through.
