02-11-2016 06:51 AM - edited 03-08-2019 04:33 AM
Im fairly new to cisco, and i'm trying to configure a 1921 router for voice and data but don't seem to be getting anywhere.
I need to configure GigabitEthernt0/0 as WAN and set up X2 VLAN's,vlan1 on GigabitEthernt0/0/0 for data
and vlan100 on GigabitEthernt0/0/1 for voice.
The voice is going to a UC540 which will manage the phones and data to a separate switch but neither work at all, cant even get an IP address by connecting directly to GigabitEthernt0/0/0.
Would the UC540 be and just forget the 1921
Any pointer to what i'm missing would be great, here is my current config.
Current configuration : 2970 bytes ! ! Last configuration change at 18:04:06 UTC Thu Feb 4 2016 version 15.2 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname FreshShop ! boot-start-marker boot-end-marker ! ! enable secret 5 $1$uNn/$aFklz9tl/OXc3gChU0sRj. ! no aaa new-model ! ip cef ! ! ! ! ip dhcp pool vlan1 import all network 192.168.10.0 255.255.255.0 default-router 192.168.10.254 dns-server 78.151.239.1 78.151.235.130 8.8.8.8 8.8.4.4 ! ! ! no ip domain lookup ip name-server 78.151.239.1 ip name-server 78.151.235.130 ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef multilink bundle-name authenticated ! vpdn enable ! vpdn-group 1 request-dialin protocol l2tp ! ! ! license udi pid CISCO1921/K9 sn FGL184125M9 ! ! username fresh privilege 15 secret 5 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ username cisco privilege 15 secret 5 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ! ! bridge irb ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 ip address dhcp ip access-group Internet-Inbound-ACL in ip nat outside ip virtual-reassembly in ip tcp adjust-mss 1460 duplex full speed auto pppoe enable group global pppoe-client dial-pool-number 1 no cdp enable ! interface GigabitEthernet0/1 no ip address duplex auto speed auto ! interface GigabitEthernet0/1.1 encapsulation dot1Q 1 native ip address 192.168.10.254 255.255.255.0 ! interface GigabitEthernet0/1.100 encapsulation dot1Q 3 ip address 10.1.1.254 255.255.255.0 ! interface GigabitEthernet0/0/0 switchport mode trunk no ip address ! interface GigabitEthernet0/0/1 switchport access vlan 100 no ip address ! interface GigabitEthernet0/0/2 no ip address ! interface GigabitEthernet0/0/3 no ip address ! interface Vlan1 description Data no ip address ip nat inside ip virtual-reassembly in bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan100 no ip address ip nat inside ip virtual-reassembly in ! interface Dialer0 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip mtu 1432 ip nat outside ip virtual-reassembly in encapsulation ppp dialer pool 1 ppp authentication chap callin ppp chap hostname ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ppp chap password ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ no cdp enable ! interface Dialer1 no ip address ! interface BVI1 description Bridge to Internal Network ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! ip forward-protocol nd ! no ip http server no ip http secure-server ! ip nat inside source list 1 interface Dialer1 overload ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 0.0.0.0 0.0.0.0 dhcp ! ! ! ! control-plane ! bridge 1 route ip ! ! line con 0 logging synchronous line aux 0 line 2 no activation-character no exec transport preferred none transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 login transport input all ! scheduler allocate 20000 1000 ! end
02-12-2016 01:04 AM
I think I would just plug the circuit directly into the UC540. I don't see what you gain by using two devices to do this.
02-12-2016 02:00 AM
I did post an answer into the thread you posted in WAN.
Jon
02-12-2016 02:21 AM
I cant see the reply's in that thread even though I get the notification.
I will have a go tonight and see where I get. I was asked to configure 0/0/0 for data
and 0/0/1 for voice which is what the boss wants for some reason so was trying to get that going.
I will suggest he uses the UC540 if I don't get anywhere tonight
02-12-2016 02:33 AM
Okay, if you need to use those ports then you need to have IPs on your SVIs ie. the "int vlan x" parts of your configuration.
Jon
