02-12-2016 08:01 AM - edited 03-08-2019 04:34 AM
I have a simple question I'm having difficulty finding an answer to. Can I use overlapping VLSM statements to break off only one (or a few) /30s in a different area? Something like:
Solved! Go to Solution.
02-13-2016 02:31 AM
Hello and welcome at the CSC forum!
Yes, you can use overlapping network statements for different areas under the same OSPF process. You can find a more detailed answer in this discussion: https://supportforums.cisco.com/discussion/12510021/conflict-router-ospf-netwok-commands
network 192.168.253.64 0.0.0.4 area 91
I guess there is a typo in the wildcard mask? The IOS OSPF implementation does not allow discontiguous wildcard masks in network statements. You can only use 0.0.0.0, 0.0.0.1, 0.0.0.3, 0.0.0.7 and so on.
Rolf
02-13-2016 02:31 AM
Rolf
02-17-2016 07:42 AM
Thanks, I indeed fat fingered the mask, meant 0.0.0.3. I did run tests and it works fine. I was able to add a network statement for the /24 and a few different ones for specific /30's.
Thank you.
02-17-2016 08:08 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As you've found, and as Rolf explained, it can be done.
Years ago, you had to be careful with how you sequenced your network statements, for example, in your OP you have the larger address block first, so none would make it to the more specific. In later devices (or IOS versions), I believe OSPF will reorder the overlapping network statements, so the more specific is matched first.
