Hi all,
I'd like to wish you guys are all the best and healthy with your family in this new year!
Recently, I have a company from my well developed Cisco 4500E series switches in my office. Simply say, some server switch port was enforce to be disable due to too many exceeding layer 2 broadcast triggered, may be virus or vulnerability somehow. My job is to wake up at the midnight then manually enable the port every time, that was so evil ~_~
So my question is it the only way to discard those annoying broadcast or shut down the ports by defined ACL. Any advice to predict the broadcast from the server, or it can effectively suppress the broadcast frame but don't let the ACL suspend the port?
Very appreciate if you could give some suggestion on it.
Eddy
