Remove Bulk Mac addresses from ISE Endpoint group
ramesh_kumar
Is there any way we can delete bulk mac addresses from ISE Endpoint identity group?
AIN UL BADAR
Level 4
Level 4
Ramesh,
Did you find a way to do it?
Ain
can anyone answer this issue ?
You can use rest Api+Script to remove bulk mac address from identity group.
1.Retrive endpoint id from ise using get request.
2.use the endpoint id then send a post request with payload static group assignment = "false"
You can access the External RESTful Services SDK from the following URL:https://<ISE-ADMIN-NODE>:9060/ers/sdk.
-Aravind
-Aravind
Mike.Cifelli
You should be able to do this:
Administration->Identity Management->Identities->YOUR Endpoint Group
You have two options:
1-delete selected
2-delete all
You can also statically add/remove macs under Context Visibility
HTH!
