02-28-2016 01:26 PM - edited 03-21-2019 08:52 AM
Hello! I am trying to set up an SPA514 phone (and others), but I am having problems
trying to set up the unused line keys as BLF/Speed Dial keys... I am trying to
do the provisioning, but I also have the same problems with the web interface
on the phone.
The phone is at the 7.6.1 firmware version (the latest, as of today).
I have been using the Cisco Small Business SPA300 Series, SPA500 Series, and WIP310 IP Phone Administration Guide,
located at:
and in the material under
I see these instructions:
Step 1 Click Admin Login > advanced > Voice > Phone.
Step 2 In the Line Key to configure (line 4 in this example):
a. From the Extension drop down list, choose Disabled.
b. Enter the following string in the Extended Function field:
fnc=blf+cp;sub=Stephanie@$PROXY;ext=300@$PROXY
fnc=type;sub=stationname@$PROXY;ext=extension#@$PROXY
– ext or usr: extension or user (the usr and ext keywords are interchangeable)
Step 3 Click Submit All Changes. After the phone reboots, the phone in this example displays the following color LEDs for the monitored lines:
These instructions don't work!
Firstly, if I make (eg) extension 2 (I am using only 1 line) Disabled, then it will not show any label for that button, nor will anything happen if I press that button!
So, I set it to "1", as any other number will not work. After the phone reboots, I then get the label on the LCD for that button, but.... when I press it, it asks for me to "Enter a number:" The same results apply to the speed-dial entry.... what do I have to do to get these buttons to dial the associated extension when I press them?
Solved! Go to Solution.
03-01-2016 03:19 PM
Well. I have no SPA514 here, but the SPA504G should be similar enough. The configuration that works for me follow:
<Extension_3_ ua="na">Disabled</Extension_3_>
<Short_Name_3_ ua="na">2540</Short_Name_3_>
<Share_Call_Appearance_3_ ua="na">share</Share_Call_Appearance_3_>
<Extended_Function_3_ ua="na">fnc=blf+sd;ext=2540@$PROXY;sub=2540@$PROXY</Extended_Function_3_>
So try it and lets me know. The Line 3 key should have 2540 label and the relevant key should light,
02-29-2016 07:39 AM
SPA endpoints are supported in the SMB community in CSC
02-29-2016 07:55 AM
It seems you are running phone in SIP mode, with no Call Manager.
In such case you are off-topic here.
Use blue [ EDIT ] button (upper right) to reclaim your question to Small Business -> Voice and Conferencing -> SPA IP Phones
I will try to help you once thread become moved in proper community.
02-29-2016 06:05 PM
Is this better?
02-29-2016 07:18 PM
Yes, but be patient please, there are 4am and I need sleep a lot.
02-29-2016 07:31 PM
Hmm, you must be in Europe. Sweet Dreams; now I go to my rest; and look forward to any help you can offer. Many thanks!
03-01-2016 01:46 PM
Oh, btw, I attached the xml for provisioning, a bit sanitized.
03-01-2016 03:12 PM
OK. So sensitive CSC antispam engine considered this thread inapropriate so I has been unable to respond. But now, the thread is back. Lets go.
03-01-2016 03:19 PM
03-01-2016 09:23 PM
Dan--
Many thanks. Setting the Share_Call_Appearance_x_ to "share" was incorrectly specified in the documentation. I hope they fix it, as it cost me a lot of wasted time. And, they might have specified the fnc=blf+sd+cp as a possibility also. Now, all my keys display, and act as one would expect. Many thanks!
03-02-2016 12:16 AM
"share" has been mentioned as requirement somewhere. But I don't remember where I has read it. May be it has not be Administrators Guide but an other document.
According blf+sd+cp - I still don't understand in full the exact relationship between ext= and sub= as well as their relationship to particular sd/cp/blf function. So my advice is - just try it.
