03-01-2016 03:35 PM
Hi, I'm trying to connect one Cisco 4507 to a 3750x using a Single mode fiber between to buildings, is this compatible?
10Gbase-SR to SFP-10GBase-LR? if so, any idea why I couldn't get link between them?
Solved! Go to Solution.
03-01-2016 03:57 PM
03-01-2016 03:57 PM
Won't work.
It's either SR to SR or LR to LR.
03-02-2016 09:35 AM
SR definitely won't work. SR generates a multi-mode signal. It expects a 50 micron core and has a different propagation pattern than single-mode. LR generates a single-mode signal. A single-mode fiber core is 9 micron. It travels farther than a multi-mode signal.
This concept applies whether it's 1 Gb or 10 Gb. Or higher.
04-28-2016 02:39 AM
it definitely won't work. 10GBASE-SR uses multimode fiber, while 10GBASE-LR operates over single-mode fiber. Maybe a mode conditioning patch cable will help you to solve this problem.
