03-02-2016 11:30 AM - edited 07-05-2021 04:42 AM
I am experiencing an issue where our guest SSID is broadcasting and bleeding out the building. It was reported that people in the parking lot can access our guest network. Below are my questions:
1. How do I block the Wireless signal travelling outside the building.?
2. how secure is this capwap encryption? what protocols does it use?
appreciate in advance any feedback.
Farhan
Solved! Go to Solution.
03-02-2016 06:05 PM
1. one option is to reduce the TX power, it will reduce the coverage area.
the transmitted power is reduced to limit the effect of RF interference. The reduction has a negative effect on the radio coverage. The transmitted power is directly proportional to the radio coverage area. Therefore, the weaker the transmitted power, the smaller is the radio coverage area.
2. Capwap is the communication between access point and WLC for data encryption .
03-02-2016 06:05 PM
