03-05-2016 02:14 AM - edited 03-08-2019 04:50 AM
Hello All,
we replaced GBIC in port GigabitEthernet1/3/21.
The port is now in inactive state. What is the reason the port is inactive ?
GigabitEthernet1/3/21 is up, line protocol is up (inactive)
Hardware is Gigabit Ethernet Port, address is 64f6.9ded.1760 (bia 64f6.9ded.1760)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLH
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 80000 bits/sec, 47 packets/sec
1780298 packets input, 257553534 bytes, 0 no buffer
Received 45254 broadcasts (23272 multicasts)
11186443 packets output, 1936312449 bytes, 0 underruns
0 output errors, 0 collisions, 17 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
WS-C4510R+E is runing on IOS-XE Version 03.06.00.E RELEASE SOFTWARE (fc3)
------------------ show module ------------------
Switch Number: 1 Role: Virtual Switch Standby
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model
1 12 10GE SFP+ WS-X4712-SFP+E
3 48 1000BaseX SFP WS-X4748-SFP-E
4 24 1000BaseX SFP WS-X4724-SFP-E
5 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E
7 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E
10 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E
Switch Number: 2 Role: Virtual Switch Active
Thank you
Jan
03-05-2016 04:21 AM
Maybe a bug in the IOS?
03-07-2016 07:42 AM
can you paste the config ?
03-07-2016 11:13 PM
here is the current configuration of port :
interface GigabitEthernet1/3/21
switchport trunk allowed vlan 1,4,16,55,202,819
switchport mode trunk
storm-control broadcast include multicast
storm-control broadcast level 5.00
storm-control action trap
spanning-tree guard root
Also, we tried to put the interface in default state and then reconfigure it but it didn't help.
Jan
03-08-2016 07:37 AM
Do you see anything in the logs when you do this?
03-10-2016 01:47 AM
nothing important in the logs.
Here are questions/answers round :
yes
Mar 9 06:54:51.471 UTC: %C4K_IOSINTF-5-TRANSCEIVERREMOVED: Slot=3 Port=21: Transceiver has been removed
wr#sh int g1/3/21
GigabitEthernet1/3/21 is down, line protocol is down (inactive)
wr(config)#int g1/3/21
wr(config-if)#shut
wr(config-if)#do sh int g1/3/21
GigabitEthernet1/3/21 is administratively down, line protocol is down (disabled)
wr(config-if)#no shut
wr#conf t
Enter configuration commands, one per line. End with CNTL/Z.
wr(config)#default int g1/3/21
Interface GigabitEthernet1/3/21 set to default configuration
wr(config-if)#switchport
wr(config-if)#switchport mode trunk
wr(config-if)#switchport trunk allowed vlan 1,4,16,55,202,819
wr(config-if)#storm-control broadcast level 5.00
wr(config-if)#storm-control action trap
wr(config-if)#spanning-tree guard root
wr(config-if)#end
hw-module module <n> reset where n is slot no.
Now, we must wait for maintenance window when we will reset the module......
03-10-2016 09:06 AM
Is this the only port in this module saying inactive or there is more?
03-10-2016 09:55 AM
Yes, only one port saying inactive.
