03-07-2016 02:28 AM
Hi there ,
we have been using Cisco UCS with B22_m3 and B222_m3 series for a while.We use updating template and added new vlans to our system .
But when i applied the service-profile , it does not get associated with my servers at the moment.It says "Configure Evaluate Association" and in progress for a long time.
any ideas with this??
Solved! Go to Solution.
03-08-2016 08:54 AM
I can give you some commands to get the output of the DME and other internal components that can tell us what the system is doing behind the scenes but the output will be recursive and too long to be pasted here... can you open a TAC case? If not, can you see if other servers have applied the vlan to their interfaces ? (trying to isolate the issue here...)
-Kenny
03-08-2016 08:28 AM
Can you go to the General tab, pull KVM and see what the server is really doing? I see it only registers 8 tries at the time the screenshot was taken so it does not look like a lot of time.
-Kenny
03-08-2016 08:35 AM
hi Keny,
it has been more then 3 months, we completely forgotten that ,
The servers are operational at the moment ,and lots of virtual machines on them.
But the required vlans does get applied to the hosts..
03-08-2016 08:37 AM
where do you see the vlan is not added? are you checking the running config of the veth from nxos? If so, can you share that and the vlan ID in question?
-Kenny
03-08-2016 08:45 AM
from the nxos output as can be seen below ,but we had added more vlans , but not apllied ,for example vlan 303,331 and 504
interface Vethernet776
description server 1/4, VNIC EsxProdB
switchport mode trunk
untagged cos 4
no pinning server sticky
pinning server pinning-failure link-down
switchport trunk native vlan 1000
switchport trunk allowed vlan 1,110-112,115,125,200,301,400-401,507,509,603-605,1000
bind interface port-channel1288 channel 776
service-policy type queuing input org-root/ep-qos-GoldByOrcProd
no shutdown
03-08-2016 08:49 AM
Are you using UCS Central? and do you see any pending activities in UCSM?
-Kenny
03-08-2016 08:50 AM
no ucs central
just one ucs chassis at the moment
03-08-2016 08:54 AM
-Kenny
03-08-2016 08:57 AM
it is not applied to any of the servers, they are all in the same situation when we look at them .
also from the nxos , i can see that it is not applied.
I am not sure about the TAC case, i have to look for it
03-08-2016 08:59 AM
ok.. TAC can do some live debugging of internal communication to see where the update is getting stuck or who is not pushing it.
Good luck!
-Kenny
03-08-2016 09:09 AM
Ok
thank you for your interest
have a nice day
03-08-2016 09:10 AM
Pleasure to help... You have a nice day too.
-Kenny
