03-09-2016 10:43 PM - last edited on 03-25-2019 07:29 PM by ciscomoderator
I found that this UCCX version 9.02 error also applies to UCCX version 11.0.1.10000-75.
admin:show version active
Active Master Version: 11.0.1.10000-75
Active Version Installed Software Options:
uccx-language-pack_19-11.0.1.10000-1.cop
admin:set weba
admin:set webapp se
admin:set webapp session ti
admin:set webapp session timeout 540
Continuing with this operation will set the session-timeout for web sessions to 540 minutes after the 'Cisco Tomcat' service has been restarted or after the server has been rebooted.
Continue (y/n)?y
Internal error: Tomcat session-timeout values were not updated.
See attached image from CLI session
03-10-2016 12:56 AM
You are correct that this command still does not work for UCCX even in the latest version i.e., 11.x and therefore the defect is still in an Open state.
Deepak
03-10-2016 01:22 AM
Hi Deepak.
As my PICA does not function currently and the CSCun28885 does not reflect that other versions are influenced by this. I thought I'd bring it to attention here.
Thank you for confirming. Do you know if there is a solution on route for this. It's pesky, beeing logged out every 15 minutes of inactivity.
With kindest regards
Claus Pedersen
03-10-2016 01:25 AM
Roadmap questions cannot be answered here unfortunately. Please contact your Cisco SE or TAC for more information on this.
Deepak
