03-11-2016 02:44 AM - edited 03-10-2019 12:36 AM
I have installed ASDM launcher 716 on Windows 7. It does not appear on startup menu and keeps on giving me an error that Demo software is not installed. Please install demo software from http://www.cisco.com/pcgi-bin/tablebuild.pl/asa"
Please help!
03-11-2016 02:55 AM
Hello
We are currently working on it. Here is the defect for your reference:
Demo ASDM versions
CSCuy15315
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy15315/?reffering_site=dumpcr
Dinesh Moudgil
P.S. Please rate helpful posts.
07-07-2016 06:59 PM
Wow.. this must be a really difficult fix...
04-03-2017 02:56 PM
I had the same problem, and fixed. Follow this steps to solve it:
OS installed in my computer : Windows 7 Ultimate 64 bits
ASDM Demo Version installed : ASDM 7.1 for ASA
1- Uninstall any java more recent version you have.
2- Uninstall ASDM Demo
3 - Reboot PC
4 - Install Java Runtime 1.6.0.24 - 32 Bits
5 - Install ASDM Demo 7.1
6 - If you dont have any new icon on your desktop, go to
C:\Program Files (x86)\Cisco Systems\ASDM
7 - doubleclick "asdm-launcher " in that folder
8 - Select "Run in DEMO MODE" and in "select version" choose 7.1(4)
In my case , after this steps, everything is working fine now. Remember to reboot after uninstall Java RE, otherwise it wont work.
01-31-2018 03:13 AM
Its working ....TQ
Ramesh Bylapudi
