03-11-2016 08:05 AM - edited 03-08-2019 04:55 AM
my question is pretty simple: is it possible to configure two (or more) vPC peer links between the two switches belonging to a vPC domain? The purpose is to configure a vPC domain where two different peer links are used to carry different VLANS, instead of having a single peer link for all the VLANS (see attached image).
Thanks in advance
Solved! Go to Solution.
03-11-2016 09:32 AM
Its not supported.
If you are concerned about bandwidth add more links to Peer link.
Madhu
03-11-2016 09:32 AM
Its not supported.
Madhu
