03-11-2016 11:44 PM
Hello Support
03-14-2016 05:20 AM
Have you tried to update or replace configs first. It sounds like the media server has a different config than the camera and by running one of the above commands will fix that issue, then you can proceed to delete.
03-15-2016 12:32 AM
Hello
I didn't change anthing in VSM, and also tried to update or replace config but same.
Also I tried to see stream on Web browser, but it not showing anything?
Do you think its hardware issue?
03-16-2016 07:46 AM
I would say that if you cannot obtain a live feed from the camera UI itself first, it may just be a camera issue. You should contact Cisco TAC and open a support case.
03-17-2016 01:27 PM
reset the camera first and see if it comes back up. If not go with Scotts reply and see if its under warranty with TAC.
03-14-2016 05:37 AM
Is there anything on the network side that would prevent the VSMS instance from actually obtaining the video feed from the camera?
Also, I recommend trying one of the initial, default camera templates as opposed to anything custom to eliminate it actually being some quirk of stream configuration that the camera could be taking issue with.
03-15-2016 12:25 AM
Hello
First of all thanks for your reply.
I have another 22 cameras that working fine (in this network only I have cisco switch), this one also was working for 2 years but suddenly stop and show me this error. I did your recommend but still same.
