Hi Guys,
My firewall has admin,system and manually created context.i want each context to back up the configuration to the prime machine,at the moment it only takes admin context. Can you provide me an idea how should i do it ?
And also how to generate audit logs using asdm & cli in the firewall ?
Others logs such as syslogs i am able to generate in the asdm to send out.
Thank you
