Does anybody know which ASA devices supports the MIB CISCO-FIREWALL-MIB and the
following OID: 1.3.6.1.4.1.9.9.147.1.1.2.2.1 , this Object looks like it contains the same information as the show conn command which lists all the connections traversing though the firewall
http://www.oidview.com/mibs/9/CISCO-FIREWALL-MIB.html
CISCO-FIREWALL-MIB:cfwNetEventsEntry
Access: Not-Accessible
Type: CfwNetEventsEntry
An entry in the table , containing detailed information
about an event. Note that this table may be sparse.
If Network Address Translation is not enabled
cfwNetEventInsideSrcIpAddress and
cfwNetEventInsideDstIpAddress will not be instantiated
in the row. If Port Address Translation is not enabled
cfwNetEventInsideSrcIpPort and
cfwNetEventInsideDstIpPort will not be instantiated
in the row. Entries are added to this table at the
same time that events are added to the cfwBasicEventsTable.
These two tables may be configured to be different
sizes so there may not be a one-to-one correspondence
between rows in the two tables.
