03-31-2016 02:40 AM - edited 03-12-2019 12:33 AM
Can anybody help me in configuring the following?
I have a router with zone based firewall configured.
I have the following port redirect:
ip nat inside source static tcp 192.168.1.100 80 172.24.10.100 8888 extendable
172.24.10.x is my pool of outside addresses.
I need to reach the server 192.168.1.100:80 from any outside address (by the address 172.24.10.100:8888 )
which class map type inspect do I have to configure?
Johnny
03-31-2016 02:54 AM
You can use a class-map that references an ACL. This ACL allows the traffic to the real IP/Port of the server.
03-31-2016 03:10 AM
do you mean the following?
access-list 101 permit tcp any host 192.168.1.100 eq 80
in the policy map do I have to put an inspect or a pass statement?
Johnny
03-31-2016 03:17 AM
Yes, the ACL is ok, although I would use a named ACL.
The action "pass" is for unidirectional flows. If you want that your server can send answers back to the client (probably yes ;-) ) then you need to "inspect" that traffic.
