Does any command can limit the traffic from particular port on Cisco 2960s with LAN-lite?
Hele Du
Hi Experts,
I encountering a traffic issue which is client send lots of traffic from particular port.
6 Replies 6
Dennis Mink
use, for instance to bring the limit down by % (between 10 and 90), configure this on your port:
srr-queue bandwidth limit
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Is this command only for ergess driection?
Maybe using "bandwidth + percentage" is correct answer.
Hi back,
you can only limit the egress rate of a port with that command.
Which means the port is, in case of you, putting 10 (as lowest configurable option, so will not be able to limit for example a 100MBit-Port down to 5MBit) after that command, in "pause" mode 90% of its given transmit time ;)
For pushing down the traffic going INTO and EGRESSING from that port you need policing, will look like this:
mls qos
ip access-list extended LIMITACL
 permit ip any any
class-map match-all CLASS_LIMIT20MBIT
 match access-group name LIMITACL
policy-map LIMIT-20MBIT
 class CLASS_LIMIT20MBIT
  police 20000000 1000000 exceed-action drop
interface FastEthernet0/1
  srr-queue bandwidth limit 20
 service-policy input LIMIT-20MBIT
But policing will produce taildrops, and so you will have not that nice traffic behaviour due tue the TCP syncing issue. Proper shaping is AFAIK not available on the smaller Catalysts, especially not on a Layer2-Switchport.
Hi Andreas,
Thank you for your answer.
The feature police seems only support on LAN-base platform, I cannot issue Class-map command on my switch which is LAN-lite
ouch...ok, i didn´t read the detail about LAN-lite ;)
