sx20 router nat configuration
equinox198
Is there a cisco validated config for exposing a SX20 unit on a router?  I have a 2911 router.
I don't have a firewall at the site.
I know I can nat the device and enable the following incoming ports the on public ip
udp 1719
tcp 1720
tcp 5555 6555
tcp 11000 20999
udp 2326 - 2845
Do i need to enable any inspect rules for outgoing traffic from the unit?
I know on the sx20 unit, i would have to set the NAT to auto and the call mode direct.
Wayne DeNardi
If you do a search for SX20 Standalone in these forums, you will find much information on the ports and requirements for using a SX20 behind a router.
For all video conferencing purposes, and H.323 and SIP packet inspection/fixup should be disabled on your router.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
VCsupport17
Level 3
Level 3
Have you made this work?
Can you share the configuration of your router.
