04-11-2016 03:00 AM - edited 03-18-2019 05:47 AM
My ExpressWy are actually used for Jabber.
When my Publisher is down, the are no Jabber outside of network.
If I check ExpressWay-C logs, I have this error (every 5 minutes) :
edgeconfigprovisioning: Level="ERROR" Service="UDSManager" Detail="UDS get version request failed" UDS=CUCM-2_IP" Reason="[<twisted.python.failure.Failure <class 'OpenSSL.SSL.Error'>>]" UTCTime="2016-04-11 08:59:40,156"
If I check Unified CM servers configuration, I have :
cucm-1.seconddomain.com administrator On CUCM-1_IP, CUCM-2_IP Default deployment View/Edit
cucm-1.firstdomain.com administrator On CUCM-2_IP, CUCM-1_IP Default deployment
Currently found Unified CM nodes
Publisher address Name Protocol Version Status
cucm-1.seconddomain.com CUCM-1_IP TCP 10.5.2 TCP: Active
cucm-1.seconddomain.com CUCM-2_IP TCP 10.5.2 TCP: Active
cucm-1.firstdomain.com CUCM-1_IP TCP 10.5.2 TCP: Active
cucm-1.firstdomain.com CUCM-2_IP TCP 10.5.2 TCP: Active
No errors but the Subscriber is listed in the Published address (with Publisher name).
I don't knwo why.
In my certificate manager (CUCM), I created a Multi-Server(SAN) certificate :
CUCM-1-ms.pem
Extension: SubjectAltName (OID.2.5.29.17)
Critical: false
altNames: 9 names
1) CUCM-1 (dNSName)
2) cucm-1.seconddomain.com (dNSName)
3) CUPS-1.firstdomain.com (dNSName)
4) cups-1.seconddomain.com (dNSName)
5) cucm-2.seconddomain.com (dNSName)
6) firstdomain.com (dNSName)
7) cucm-1.firstdomain.com (dNSName)
8) seconddomain.com (dNSName)
9) cucm-2.firstdomain.com (dNSName)
04-12-2016 02:48 AM
In the Publisher, I can't resolve cucm-2 (utils network host cucm-2).
From Publisher (cucm-1), I can resolve cucm-2.firstdomain.com and from Subscriber I can resolve cucm-1 and cucm-1.firstdomain.com.
But, If I do a DNS lookup from ExpressWay C to cucm-2, it's OK... So... I don't know.
05-02-2016 05:39 AM
I resolved my problem by adding DNS and domain in cucm-1.
