Team,
Is it difficult to write a script which performs a shutdown on a Cat3650 interface once attenuation has reached >17dB (29.5 is current in the output below)?
Thank you,
Switch#show interface transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Tx Power Rx Power
Port (Celsius) (Volts) (dBm) (dBm)
Gi1/1/1 29.4 3.30 -5.5 -29.5 --
