04-12-2016 07:17 PM - edited 03-01-2019 12:41 PM
My blade contain two server types B200M3 with 2 adapters and B200M4 with 1 adapter
When vHBA/vNIC placed automatically
They all placed on one adapter for B200M4 and distributed on the 2-adapters on B200M3
Do I need to have 2 separate placement policies for each of the servers
So to have them on one vCon for B200M3 and to separate on 2 vCons for B200M4, or it will give the same effect ?
Also do I need to place vHBA in above order specially the servers will boot from SAN ?
04-12-2016 08:56 PM
If you assign a service profile with vHBA/vNICs pinned to VCON2 and assign it to a blade that doesn't have a second card the profile will just ignore the VCON2 settings.
Please be aware of the Admin Host Port settings that only apply to the M4 equipment using the VIC 1340/1380:
https://supportforums.cisco.com/discussion/12565226/vic-1340-pci-placement-issues
04-13-2016 05:41 AM
Hi Steven,
Thank you very much to make me note that.
I do your advise for B200M4 which contain 1 adapter
But how to do vnic/vhba placement for a server with 2 adapter
I put vnic and vhba ports of FI-A on VCON1
then vnic and vhba ports of FI-B on VCON2
And I have 2 vnic with failover on VCON1
When I check VIF path as attached
I found all is ok but the failover ports is going out on path A1 and path B1 which I think is related to adapter 1
So if Adapter 1 come down, then I'll lose this vnics
I think it is because it is one vnic which is on one adapter
So I think to create a second vnic for vmotion for example on the second adapter
But with this, I'll have 4 vnic for vmotion , on A1, A2, B1 and B2
So what do you think ? or it is useless to do that ?
thanks
