04-14-2016 01:22 PM - edited 03-18-2019 05:48 AM
Can you use TMS to manage multiple MCUs, say some MCUs for ad-hoc conferencing and other MCUs for scheduled?
Solved! Go to Solution.
04-14-2016 01:47 PM
There might be better ways to achieve this, but off the top of my head:
This is all assuming you're not scheduling the ad hoc calls, but just letting the user connect to the ad hoc MCU themselves from the endpoint. For monitoring, you can use CCC to monitor both scheduled and ad hoc conferences on the MCUs. See the "Routing" section on pg 32 and the"CCC" section on pg 181 in the TMS 15.2 Admin Guide.
Conductor would most likely be the best solution here to help manage the multiple MCUs.
04-14-2016 01:47 PM
