Hello all,
A little advice please...
I recently set up Vlans and L3 switching in a small network. I spent some time tweaking the Access-lists to obtain the desired results, and finally achieved my goal. One observation I have is that when writing access-lists on the SG-300 I find I have better results working in the command-line rather than the GUI - as in the GUI I often have an error, telling me that a line already exists, though I know it does not.
I work in notepad as I was taught, writing out the access-list and making changes as needed. I then copy and paste the final access-list into the putty-based command line, then apply the access-list via command line too.
eg.
ip access-list extended ACL_CHEESE permit tcp 172.16.1.1 0.0.0.0 any 172.16.2.1 0.0.0.0 80 ace-priority 10
ip access-list extended ACL_CHEESE deny tcp 172.16.1.1 0.0.0.0 any 172.16.2.1 0.0.0.0 80 ace-priority 20
int vlan 10
service-acl input ACL_CHEESE
This applies my Access-list to the correct vlan. Then suppose I want to change my access-list, I would type
no ip access-list extended ACL_CHEESE
This would delete ACL_CHEESE and remove the service-acl input ACL_CHEESE statement from vlan 10
Then I would modify my ACL_CHEESE in notepad and re-paste the modified version into the console and re-write the service-acl line for vlan 10.
However, I noticed that the changes were not instant when using this method. Is that because the switch is busy trying to clear the access-list from it's TCAM table and re-write the new access-list into the TCAM table, so it can be processed in hardware? If so how long does this take? I know it depends how busy the switch is and how long the access-list is etc, but is there a ball park figure?
There is a command in ASA firewalls, which is clear xlate. I understand this to mean that all current translations (including Access-list rules) are cleared and reprocessed immediately. Is my understanding correct, and is there something which I can do in the SG300 switches to achieve a similar goal?
Or is there simply a better way of writing/editing access-lists which avoids this problem?
Doug
