04-20-2016 01:40 AM - edited 03-03-2019 08:11 AM
hi;
we have asr 1001x with Cisco IOS XE Software, Version 03.17.00.S and we are making nat overload with pool.
===config
ip nat pool OUTNET x.x.x.2 x.x.x.254 prefix-length 24
ip nat inside source list 1 pool OUTNET overload
access-list 1 permit y.y.y.0 0.0.31.255
===config
it is working nice. But clients outside ip addresses changing randomly and quickly. what we want is: when the client take nat outside ip address it has to be stay on it 1 hours.
i tried with type match-host but it is not help.
is there any way to do it ?
thanks;
04-21-2016 01:52 AM
I don't know the answer.
I suspect if you increase the NAT timeout values, it will keep the existing NAT entries longer. Check out this document:
I would look at "ip nat translation timeout ...." in particular.
04-21-2016 03:03 AM
thank you philip.
also i tried that one "ip nat translation timeout" it doesnt help.
and its default value is : Timeouts: default 86400
