Add custom mib to Prime 3.0
davy.timmermans
Level 4
Level 4
I would like to know when the secondary WLC in the HA cluster is active. This should be possible via CISCO-LWAPP-HA-MIB
To achieve this I've downloaded Standard-MIBS-Cisco_8.1 and MIBS_8.1 from the controller software page.
My problem is that I'm not able to upload any of the MIB (zip/individual mib) to prime>monitor tools/monitoring policies> custom mib polling:upload mib
--> reference error, unexpected token. I'm not able to read the full error message.
dkeysell
I believe you need to import CISCO-RF-MIB before importing CISCO-LWAPP-HA-MIB.
dkeysell
upload worked.
Unfortunately the output when using these objects in prime are not 100% satisfying.
> clHAsecondarycontrollerusage should give back an integer --> but it doesn't return anything
>clHAPrimaryUnit --> returns 1 or 2 - should be true/false --> I'd hoped to send a trap eg. when false
see attached result
