04-21-2016 11:44 AM - edited 03-18-2019 11:57 AM
Hello all ,
I am trying to add MGCP gateway to CUCM , I follow all the configuration as in the attached files and It appears to be unregistered on CUCM.
I am using CUCM 11.x , Cisco Router 2921
Solved! Go to Solution.
04-21-2016 12:57 PM
And do you have a live circuit connected to that port??
Or you just configured it??
Assuming all the configuration is fine, if there's no live circuit, it will NEVER register.
04-21-2016 06:18 PM
Do you have a PRI cable plugged into that port??
04-21-2016 12:10 PM
You need add below things depending upon T1 or E1 line code and framing,switchtype will vary
1) Card type-
card type t1/E1 {Slot}
2) Controller config
controller T1
cablelength long 0db
framing esf*
linecode b8zs*
pri-group timeslots 1-24 service mgcp
description PRI
3) Bind serial interface to CCM.
Interface serial0/1/0:23
isdn switch-type primary-4ess
isdn incoming-voice voice
isdn bind-13 ccm-manager>>>>>>>>>>>>>>>>>Very imp
Also add network clock command
network-clock-participate wic X
network-clock-select 1 T1 X/X/X
* means only for T1
04-21-2016 04:26 PM
I will follow the following and keep you updated also , Thanks for helping me in all topics.
Short question here :
when I try to show the controller the command didn't work.
04-21-2016 05:51 PM
Please make sure PRI is physically plugged into your MGCP gateway as advised by Jaime .
Also enable the card type and then you should be able to see the controller . You need to use command to configure depending upon whether you have E1 or T1 circuit.
"Controller T1/E1 X/X/X"
Also don't forget to rate helpful posts.
Deepak Mehta
04-22-2016 12:47 AM
from the attachment , u can see u need to add card type command .
version 15.5
hostname VG-MHI
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
I suppose u are using BE6000S [2921 router] since I can see interface ucse .
After u enable card type in router and enter the required configuration as suggested by Deepak[+5] , u can physically shot the 1,4 and 2,5 pins of RJ-45 cable on open side of E1 cable and check on CUCM for MGCP registration as UP.
regds,
aman
04-23-2016 01:43 AM
Yes it is BE6S 2921 but I use it only as a VG , I will Plug it today with the teleco and update you all back , Thanks all for Helping
04-24-2016 06:22 AM
Please refer the link
https://supportforums.cisco.com/discussion/12476251/mgcp-not-registering-call-manager-105-router-2921-e1-configuration#comment-10426246
configure framing no-crc4 under controller E1.
also, what is status of show controller e1 and show isdn status on router?
regds,
aman
04-24-2016 10:24 AM
controller conf attached and ISDN status show that layer 1 is shut down , i think it is cable problem or a problem from teleco side
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
SHUTDOWN
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
04-24-2016 10:34 AM
To confirm, if it is really a cable or configuration issue at Telco side, try taking RJ-45 to un- terminated [open] cable and shot TX-RX pairs.
It should be error free.
regds,
aman
04-24-2016 05:46 AM
I configure it as an E1 as mention in a reply to Jamie and it looks fine on the 2921 but on cucm still unregistred !
04-25-2016 05:33 AM
Hello ,
This command did not work isdn bind-13 ccm-manager only this is available : isdn bind-l3 q931
04-21-2016 12:57 PM
04-21-2016 04:23 PM
Hello Jamie ,
Sorry I don't know what do you mean by live circuit.
04-21-2016 06:18 PM
04-22-2016 09:33 AM
No it still not connected the teleco provider switch , I thought it will be registered normali like the fxs config.
