04-21-2016 12:38 PM - edited 03-18-2019 05:50 AM
When creating conferences on the MCU, We would like to setup a weekly conference and have a randomly generated Pin each week the conf is held. I can see nothing on the MCU itself. Is their some plugin or 3rd party way we could do this?
Solved! Go to Solution.
04-21-2016 01:27 PM
The MCU platform doesn't support random PIN codes, you'll need to update the PIN yourself through the web interface if you want to change it. You might be able to use the MCU API, and change it that way.
04-21-2016 01:27 PM
04-24-2016 11:00 PM
yes, I thought that might be the case. many thanks for your reply
04-25-2016 11:44 PM
The 3rd party scheduler for Cisco Telepresence may also help - http://aurus5.com/u-meet
